Throttle body removal - Kawasaki ZX-10R.net
post #1 of 8 Old 04-02-2008, 12:56 AM Thread Starter
afskypilot's Avatar
Help! I tried removing the secondaries and stripped one of the screws and can't get it out. I am trying to remove the throttle body and have followed the instruction in the maintenance manual. Is there a secret? They won't come out...they wiggle slightly, but won't budge. Any help I can get will be appreciated. Or, how do I get the screw out without getting shavings into the engine. Thanks in advance.
afskypilot is offline
post #2 of 8 Old 04-02-2008, 01:08 AM
ZX-10R_Sinner's Avatar
You're talking about the secondaries right? I think most use a needle nose vice grips to get a stripped screw out. Most have said that heating up the end of the screwdriver and holding it on the screw for 10 seconds or so helps loosen the loctite up to get them out easier.
ZX-10R_Sinner is offline
post #3 of 8 Old 04-02-2008, 01:14 AM
sextaafondo's Avatar
Unscrew the allen screws a little more, until they are really loose. Then wiggle the throttle bodies while applying force up. They should come out.
Do not forget any FI connector plugged in.
sextaafondo is offline
post #4 of 8 Old 04-02-2008, 01:17 AM Thread Starter
afskypilot's Avatar
I've taken the allens all the way out. I'll keep trying to wiggle. I've also tried the needle-nosed vice-grips and all I am doing is getting metal shaving when they slip off. Trying to keep the stuff out of the engine.
post #5 of 8 Old 04-02-2008, 01:32 AM
bkkninja's Avatar
You're removing the throttle body assembly? or the secondory butterflies?
There are "How to" on both of the above, check it out.
bkkninja is offline
post #6 of 8 Old 04-02-2008, 01:39 AM
Do not be scared and apply more force up. It´s stuck in the rubbers
post #7 of 8 Old 04-02-2008, 02:36 AM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
as a lot of people have done, put some toilet paper in the bodies to catch the metal shavings.. what i did was i put toilet paper on there and then a little moist toilet paper on top.. this way the metals shavings stick more.
Lucky10R is offline
post #8 of 8 Old 04-02-2008, 09:54 AM Thread Starter
afskypilot's Avatar
I used a magnet to get the shavings off of the first set of butterflies, but is there any way to make sure nothing got through? Is there a way to make sure the cylinder is free of crud without having to take the engine apart? Great advice about the TP. Which I had thought of that before.
Throttle body mod??? 1bad10r Performance and Tech 25 01-27-2007 06:49 PM
need throttle body help hongthaomurphy Performance and Tech 12 07-12-2006 10:50 PM
Throttle Body Synchronisation FuTAnT Performance and Tech 6 09-15-2005 11:30 PM
Throttle body sync help! swjohnsey Performance and Tech 3 08-02-2005 09:01 AM
05 throttle body 4 sale LordBadly Parts, Gear and Accessories 2 06-27-2005 05:30 AM
