Throttle bodies/primaries problem - Kawasaki ZX-10R.net
post #1 of 13 Old 08-01-2010, 08:36 AM Thread Starter
Renewed my throttle cable recently and somethings not right. The slack in the cable seems to be fine but the bikes not running right.
It has a very rough idle and stalls when opening the throttle. If i start the bike with the throttle opened a bit it runs fine.
What I noticed is that when I start to twist open the throttle i can feel a step in the action of the throttle where the 3&4 primaries and 1&2 primaries open.
Not sure if i explained it well, but when looking at the throttle bodies, i can see the 3&4 primaries open first when i twist the throttle, until the little tab on the wheel where the cables are hits the wheel that opens the 1&2 primaries.
Are the primaries meant to open at exactly the same time? I cant seem to adjust them that way. There is a small hex locknut over an allen key stud that adjusts the slack between the 1&2 and 3&4 primaries but when I adjust it in the bike wants to idle extremely high.
Sorry if its hard to understand my description, I'm not really sure what the wheel is called where the cables attach to
ccspeed is offline
post #2 of 13 Old 08-01-2010, 08:53 AM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
On an 08 there is a throttle body vacuum synchronization adjustment. What year is yours?
08 ZX10
ronnulph is offline
post #3 of 13 Old 08-01-2010, 09:02 AM Thread Starter
its an 04 model
ccspeed is offline
post #4 of 13 Old 08-01-2010, 09:29 AM
ronnulph's Avatar
Ok here ya go with zoom-ins on some of the pics. Good luck.
ID:	133116   Click image for larger version
ID:	133117   Click image for larger version
ID:	133118   Click image for larger version
ID:	133119   Click image for larger version
ID:	133121   Click image for larger version
08 ZX10
ronnulph is offline
post #5 of 13 Old 08-01-2010, 10:49 AM
What you just posted, is that for a 3g or his 1g?
My 08 has 17k on it and has been running a little rough around the edges, and losing power. How often do the TBs get out of sync? I guess I should have it looked at as I don't have a vacuum gauge.
What would be some tell tell signs that my TBs need to be synced?
2008 ZX-10R. | Full Arrow exhaust | PCV | AutoTune | BMC Race | Driven -1+2 520 conversion | Speedohealer | Spiegler braded lines | Carbone Lorraine SBK5 | Dunlop Q3 | more to come.
IggyBcool is offline
post #6 of 13 Old 08-01-2010, 11:42 AM
ronnulph's Avatar
1st Gen
08 ZX10
ronnulph is offline
post #7 of 13 Old 08-01-2010, 11:53 AM
ronnulph's Avatar
I would guess throttle response would be erratic. I got around 16.5K on mine and my throttle is fine. A true way to tell is to get you 1 fancy vacuum meter or four simple ones and check for calibration. A bad TPS would cause throttle issues as well but most likely trigger a error code. if you want I can screen shot the 3rd gen checks/adjustments as well.
08 ZX10
ronnulph is offline
post #8 of 13 Old 08-01-2010, 05:35 PM
Well, my bike is currently in the shop getting worked on.. Valves adjustment, and everything else that he thinks needs to be adjusted and fixed..
I however, have been experiencing throttle issues.. Say 4-5k. If I would be cruising and then chop the throttle hard, it would want to shutter and hesitate. Other than that, the bike has felt like it has been losing power over time..
post #9 of 13 Old 08-01-2010, 07:22 PM
ronnulph's Avatar
Before I would go into all the hard to DIY things, I would look at the simple stuff. Type of fuel, air filter, plugs,etc,,,,,
08 ZX10
ronnulph is offline
post #10 of 13 Old 08-02-2010, 01:11 AM
Already done everything that I could do.. literally.
Gen 1 throttle bodies. 880turbo The ZX-10R 1 02-19-2010 12:40 AM
Throttle Cables, Remove Throttle Bodies? T_Bone The ZX-10R 8 07-09-2009 05:25 PM
06-07 throttle bodies greenman43 Wanted: Buy or Trade 19 04-01-2008 06:23 PM
Throttle Bodies zx10resky Performance and Tech 0 03-25-2008 02:06 PM
06-07 Throttle Bodies rated zx Parts, Gear and Accessories 2 01-23-2008 02:04 AM
