Gen 2: 2006-2007 Throttle assembly removal... - Kawasaki ZX-10R.net
post #1 of 16 Old 06-19-2012, 09:08 PM Thread Starter
TexasRider's Avatar
Ok..how the hell do you get this damn thing off?!?!?!
Air box is off..Ive loosened up the 2 clamp bolts on either side...undid the electrical harness...air hose...blah blah...but the fugger will not BUDGE! I cant see a good area to really grab and tug..but ive tried gently rocking back and forth..and it will but move...any suggestions? Im tempted to say screw changing the thermostat and just doing a good flush and clean on the cooling system but I already spent close to $40 on the parts. Also...is it possible to remove the #3&4 header pipe without removing the radiator?? Is there a way to jsut tilt it forward to get better access to the header bolts????
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #2 of 16 Old 06-20-2012, 06:08 AM Thread Starter
TexasRider's Avatar
Anyone??
07 zx10r- stolen
post #3 of 16 Old 06-20-2012, 07:20 AM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
If u never had them off.. keep rocking there r very well seated!
Putting them back will be a little tough as well so use very little lube to get them seated down..
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #4 of 16 Old 06-20-2012, 07:26 AM Thread Starter
TexasRider's Avatar
Ive never had them off personally...but im sure they were off last winter when I had the valves done. Are they set in a boot? (individual boots) When you say 'lube' will the stuff I use to instal mt tires work? (its a tire mounting lube) I Just dont wanna crack that plastic plate on top grabbing that sucker and rocking it.
07 zx10r- stolen
post #5 of 16 Old 06-20-2012, 07:39 AM
SkyDork's Avatar
Yes, they are fit down into a rubber boot that has a lip on it. I'm assuming you've already got the boot clamps loose, correct? They have a clamp like a hose clamp that you need to release first. Then you need to just pull them out. It's easier to lift on one end to start them. And they will take a lot of pulling to get them loose initially. The rubber will sort of fuse to the throttle body barrels.
But don't pull on the plastic airbox plate. Remove that plate and then lift on the TBs themselves.
#WordCrimes
SkyDork is offline
post #6 of 16 Old 06-20-2012, 07:58 AM Thread Starter
TexasRider's Avatar
yea the boot clamps are loose. How do I get the clamps for the airbox plate loose..thru the same hole in the frame for the tb clamp screws??
07 zx10r- stolen
post #7 of 16 Old 06-20-2012, 08:22 AM
SkyDork's Avatar
The airbox plate screws in from the top. There's no holding clamps for it. They are located on the top and bottom of each of the intake trumpets. Should be 8 bolts to remove and that plate will come off the TBs. Then you can get your hand around one side of the TB assembly and lift them out of the holders.
#WordCrimes
SkyDork is offline
post #8 of 16 Old 06-20-2012, 08:25 AM Thread Starter
TexasRider's Avatar
wow..i honestly never noticed then bolts holding it on..lol. Thanks!
07 zx10r- stolen
post #9 of 16 Old 06-20-2012, 08:32 AM
SkyDork's Avatar
#WordCrimes
SkyDork is offline
post #10 of 16 Old 06-20-2012, 08:33 AM Thread Starter
TexasRider's Avatar
fugger..lmao
07 zx10r- stolen
Gen 3: throttle body assembly kar1zma Wanted: Buy or Trade 2 12-02-2011 04:24 PM
Gen 4: Secondary throttle servo removal garth285 Performance and Tech 0 07-21-2011 11:13 PM
2008+ Stock Throttle Assembly and Cables! MagicMavis Parts, Gear and Accessories 1 04-13-2010 01:20 PM
Throttle body removal afskypilot Performance and Tech 7 04-02-2008 08:54 AM
FS: 05 throttle body assembly with injectors and tps ! fordfasterr Parts, Gear and Accessories 5 07-03-2007 12:43 PM
