To those with HIDs--Ballast Location - Kawasaki ZX-10R.net
post #1 of 7 Old 05-18-2007, 07:13 PM Thread Starter
scott88vr6's Avatar
I just recieved my HID kit, and am trying to figure out the best place to mount the ballast on my 07. Anyone have any suggestions? Also, which wire is pos and neg on the factory plug to the H11 bulb?
scott88vr6 is offline
post #2 of 7 Old 05-18-2007, 10:15 PM
firemedic1343's Avatar
Don't use the tape that comes with the kit. Go to Home Depot and use 3M double sided.
Most people jut fit the ballast wherever they can find room, there's not a whole of room.
firemedic1343 is offline
post #3 of 7 Old 05-19-2007, 02:59 AM
I have mine zip tied to the subframe in the rear. Where the tail of the bike flares out and back in ...behind it. I had to extend 2 wires to go up to the front but...cant see them and theyre out of the way!
NYC_ZX10 is offline
post #4 of 7 Old 05-19-2007, 03:23 AM
thrill's Avatar
Does the hid mod make a lot of difference?
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #5 of 7 Old 05-19-2007, 08:44 AM
zx10x2's Avatar
Images: 19
Send a message via Yahoo to zx10x2
I used the double sided 3m tape and stuck them inside the fairing. One on each side.
Check out this thread:
https://zx-10r.net/forum/showthread.php?t=13483
There is alot of information you can find in this forum by using the search button.
- 90 Mustang Coupe - 578 hp Grocery Getter
- 06 ZX-10 no mods - I love it
- 10 F250 Crew Cab
- 08 F-450 Crew Cab
I HAD A HANDLE ON LIFE, BUT IT BROKE OFF
zx10x2 is offline
post #6 of 7 Old 05-19-2007, 08:43 PM
Mine are on the inside of the inner fairing, right beside the forks. Used double sided 3M and no problems in about 5000 miles.
green 10r, Akro EVO 2, Hyperpro rsc, tre, pcIII, Puig DB, K&N, Purvision HIDs, Speedohealer, GONE
08 Ducati Hypermotard S GONE
08 Kawi Concours 14, Area P full sys, PCV, Flies out
speedfreak is offline
post #7 of 7 Old 05-19-2007, 09:13 PM
If you have the 2nd Gen 10R with the projectors it makes a huge difference without blinding other drivers. Try the 50 Watt kits they're sweet...33% more light.
License Plate Location hotstang46 The ZX-10R 40 10-11-2007 11:49 AM
homemade weight ballast 99vorsi Strip 21 07-31-2007 10:42 AM
Hids H11 kit on ebay. mjb929rr The ZX-10R 6 05-16-2007 05:47 PM
HID Ballast mount 06' ninjakris Pictures and Videos 14 06-30-2006 07:07 PM
Plug-in location for PC3 USB vegasdude The ZX-10R 2 06-14-2005 03:08 PM
