Gen 5: 2016- Thinner Head Gasket with Pump Gas? - Kawasaki ZX-10R.net
 27Likes
post #1 of 49 Old 08-10-2018, 10:23 AM Thread Starter
Does anyone have experience running a thinner than stock (0.85mm) head gasket on pump gas with a Gen5?
I'm curious as to how low I can go without race fuel, as I'm not racing - just lots of track days, and I don't want the hassle/cost.
I've measured my squish dimension, and it's 0.99mm. Race kit manual says optimal is 0.65mm. So, to get close I'd go to the 0.55mm gasket, but I don't want detonation problems.
Any feedback would be appreciated. Thanks.
CanyonCarver is offline
post #2 of 49 Old 08-10-2018, 02:14 PM
gaz
just inquiring, u sure that stk head gasket .85mm, all previous gens were .65mm. so deck height on ur motor only .005-.006? dont have experience with gen 5 but lots with previous gens. my std street 10 builds are .45mm hg and .015 head mill. run on pump gas no problems. my 07 has .45hg and head milled .028, does fine as long as ur moving but not a red light/stop and go traffic bike anymore. ur not gonna detonate or overheat at that suggested minimium squish on pump gas doing what u do. just surprised at those numbers. if correct going from close to .040 squish to less than .030, bike gonna really wake up everywhere in powerband. btw, tightening the squish helps prevent detonation.
gaz is offline
post #3 of 49 Old 08-11-2018, 02:11 PM Thread Starter
You are correct, sir. The Gen4 race kit manual shows .65mm as the stock head gasket dimension. However, for whatever reason, the Gen5 manual shows that .85mm is stock (see image).
Thanks for the feedback, gents. Still hoping to hear from someone who's done the mod on a Gen5, but if I don't I'll just take the plunge and go with the .55mm gasket. If it doesn't work out, I'll just have to swap back. PITA, but not the worst thing ever. Cheers.
Name:	Screen Shot 2018-08-11 at 11.55.06 AM.png
badassjake and TheRoadWarrior like this.
post #4 of 49 Old 08-12-2018, 07:40 AM
gaz
good info, learn something new everyday. .55mm will be good choice and work well no problems. great mod for power.
CanyonCarver likes this.
gaz is offline
post #5 of 49 Old 08-22-2018, 07:10 PM
I'm getting ready to build a super stock spec engine on my 2018. Is your bike the R or RR?
bbsteinnewyork is offline
post #6 of 49 Old 08-22-2018, 11:49 PM
Newf's Avatar
The Thai Kawasaki racing team mechanics used the 0.65mm head gasket when they built my Superstock engine and itís ran good on 95RON pump. You might be going a little to thin with a 0.55mm head gasket and risking PTV clearance.
Newf is offline
post #7 of 49 Old 08-23-2018, 07:57 PM
As with all builds you should measure before you send it.
theducatiman is offline
post #8 of 49 Old 08-23-2018, 08:22 PM
Going thin on the head gasket will reduce P to V clearance, however this shouldn't be the primary concern. Narrowing the gasket is general used to reduce the squish area ( Piston to head ) to control the available space in which the burn can spread before pushing the piston. Anyway if it's to tight the piston will tap the head and unload the ring reducing power and possible damage. If it's loose then the flame will travel to these areas before pushing the piston and cause a loss of power. Get it just right and make the best power.
CanyonCarver and gaz like this.
post #9 of 49 Old 08-23-2018, 09:10 PM
Newf's Avatar
Thanks for the explanation..lol
Stock Cam timing works with 0.65mm headgasket if you go thinner youíll probably have to adjust timing to have the proper PTV clearance. As already posted and from the manual, the squish should be fine with 0.55mm.
Newf is offline
post #10 of 49 Old 08-24-2018, 01:50 AM
michael4012's Avatar
I can confirm, 0.55mm squish is safe. The reason squish can be tighter 2011 onwards is the connecting rods are better designed resulting in less rod stretch. I have built 4 motors with 2011 rods onwards with exactly 0.55 squish, all were built to rev up to 14.0000 and I can confirm without doubt there has been no piston to head contact.
michael4012 is offline
Race inlet and thinner head gasket browserzx10 Performance and Tech 12 04-23-2010 04:14 PM
porting+thinner head gasket mr wael Performance and Tech 73 11-02-2007 01:26 PM
Adding a thinner head gasket TKD-NINJA Performance and Tech 7 08-19-2005 10:03 AM
thinner head gasket spoon ZX-6R & ZX-6RR Archives 3 04-10-2005 10:29 PM
Thinner head gasket miykl The ZX-10R 14 08-23-2004 07:49 PM
