Gen 5: 2016- Thinner Head Gasket with Pump Gas? - Page 5 - Kawasaki ZX-10R.net
 26Likes
post #41 of 49 Old 11-26-2018, 04:29 PM
michael4012's Avatar
Going 0.021 (0.53mm) based on my experiences is going too give you piston to head contact. Its also extremely difficult to measure accurately in 0.05mm increments, you also need to do this on all four cylinders as 0.05mm difference is found across the 4. In the past i have had the head skimmed 0.1mm shallow of where i want to be, then reassembled remeasured and then taken the head away to get the last 0.1mm off, you also have to remember that if 0.05mm is out from the skim that'll also -UCK you up. That happened to me recently and i ended up running a 0.5mm gasket instead of a 0.45mm.
SpazOnaZX and gaz like this.
michael4012 is offline
post #42 of 49 Old 11-26-2018, 05:38 PM
Originally Posted by gaz View Post
cast pistons? what engine are u building?
Its a mutt/frankenstein engine im using a 77mm flatop stock cast piston with already 31mm valve reliefs. Thats all i can say. Its allmotor grudge bike. Billet is only needed for power adders, unfortunately nobody makes oversized cast pistons.
michael4012 likes this.
John10 is offline
post #43 of 49 Old 11-27-2018, 08:42 AM
SpazOnaZX's Avatar
As long as you don't rattle it... cast pistons really don't take kindly to shock loads or pre-ignition... the little piece of ring land below the intake pocket likes to break off and and play patty-cake with the valves.... ask me how I know. But contrary to popular belief, they are damn strong... and they tend to deal with temperature and heat better than their forged counterparts.
CanyonCarver likes this.
SpazOnaZX is offline
post #44 of 49 Old 11-27-2018, 02:49 PM
Hey man we're on the same page. I've seen 05 06 Gsxr1000 do the exact same thing you described. Just broke off like a cookie, and didn't even damage the cylinder walls. OEM parts are far superior to aftermarket in my opinion. Who can compete with Kawasak R&D, some mortal with a 3 axis CNC and a block of aluminum. There is a joke in a superbike shop in britain about billet. They use it for doorstops because their heavy. It has its place for sure, but not everywhere. Carbon and cast parts where applicable are superior in weight.
John10 is offline
post #45 of 49 Old 11-28-2018, 08:44 AM
SpazOnaZX's Avatar
Usually the superiority in aftermarket parts is it allows folks to stand on the shoulders of giants... it's easy(er) to improve upon greatness than create it from scratch. That being said, OEM stuff is 99.99% a compromise of greatness VS cost, so there is generally more than enough room for improvement in a lot of places..... if you're willing to pay for it.
Having done a little bit of building shit from scratch, my buddies and I have a few jokes about 'billet' as well.... on more than one occasion I've asked random fellows about the construction material/alloy for a shiny new part, and I get 'Billet' back as an answer more times than not. We've started playing along at this point. "Oh cool, that must be the new T-7 billet, right?" or "Cool man, billet must be so much stronger than regular metal". Fun stuff.
post #46 of 49 Old 11-28-2018, 11:48 AM
post #47 of 49 Old 11-29-2018, 02:28 PM
gaz
cast pistons won't like hitting the head either. not knocking ur build john, just cautioning that .021 pth. gains from tightening squish are exponential, tightening a stk busa from .048-.050 to .032 nets some substancial hp/torque gains, from a very tight .024 to .021 is going to be miniscule, not worth gain if any/risk in my opinion.
gaz is offline
post #48 of 49 Old 12-24-2018, 10:56 AM
SpazOnaZX's Avatar
post #49 of 49 Old 12-25-2018, 08:10 PM
TheRoadWarrior's Avatar
i think you meant "diminishing" not "exponential" ;)
TheRoadWarrior is offline
Race inlet and thinner head gasket browserzx10 Performance and Tech 12 04-23-2010 04:14 PM
porting+thinner head gasket mr wael Performance and Tech 73 11-02-2007 01:26 PM
Adding a thinner head gasket TKD-NINJA Performance and Tech 7 08-19-2005 10:03 AM
thinner head gasket spoon ZX-6R & ZX-6RR Archives 3 04-10-2005 10:29 PM
Thinner head gasket miykl The ZX-10R 14 08-23-2004 07:49 PM
