Think this is a problem - Kawasaki ZX-10R.net
post #1 of 6 Old 06-27-2010, 01:07 PM Thread Starter
Well i think i found why the bike won't stay running. Which brings up a couple questions....
1. Is it normal for both the stator and rectifier to crap out together?
2. Is there any better aftermarket type or is the stock replacement all there is?
3. In searching ive seen that this is relatively common, is there any maintenance/prevention tip/trick to prolong from happening again?
Thanks.
Damian...aka Big D.
Black '11 ZX14.....aka Ms Peppa
Black '07 ZX10.....aka Da Mistress....sold...
dvls-10 is offline
post #2 of 6 Old 06-27-2010, 01:16 PM
NinjeR's Avatar
Preventive maintainence...NONE. Not that I know of.
Yes, when either one of them go, it's not unusual for it taking out the other..well it works with the 3, battery, stator, rectifier.
No aftermarket for a BETTER performance and reliability, they are about the same.
NinjeR is offline
post #3 of 6 Old 06-27-2010, 01:25 PM Thread Starter
Thanks...guess im going to dealer in the morning.
Damian...aka Big D.
dvls-10 is offline
post #4 of 6 Old 06-27-2010, 03:05 PM
thrill's Avatar
Overloading can easily cause the stator burnout. The stators are only ample enough for the factory load, so even upping the headlight wattage will do it
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #5 of 6 Old 06-28-2010, 05:37 AM Thread Starter
Ok that does shed some light on it. I did install a HID. But it has the all the stuff for it, nothing was rigged. I even have it set to my high beam switch, so that i turn it on after bike is running.
Damian...aka Big D.
dvls-10 is offline
post #6 of 6 Old 07-27-2010, 07:58 PM
rayszx10r's Avatar
Send a message via AIM to rayszx10r
did you end up having to put a rectifier on too.
rayszx10r is offline
Need some help if its not a problem to ask. vladibg General Motorcycle Discussions 2 05-15-2010 05:08 PM
I've got a problem... Stealth Rider Performance and Tech 47 06-21-2009 07:42 PM
problem slav Performance and Tech 10 03-28-2009 04:48 PM
First problem..... mach_man_187 Performance and Tech 24 08-24-2006 06:08 PM
Anyone have the same problem as me??? brianhknott The ZX-10R 18 11-15-2005 04:55 PM
