Thin Head Gasket for Street - Kawasaki ZX-10R.net
post #1 of 11 Old 01-30-2010, 08:22 AM Thread Starter
afskypilot's Avatar
Greetings,
I purchased the thinner head gasket for my 07 ZX10R but before I install it I had a question. I use this bike for both racing and riding back and forth to work and weekend trips. I know I will get more hp by installing the thinner gasket but will I have issues with using it for everyday use?
afskypilot is offline
post #2 of 11 Old 01-30-2010, 09:42 AM
Speed Freak
garth285's Avatar
not at all. I'm running the thin gasket and I have my head decked .015" so I'm in the area of 14.2:1 compression on pump 93 gas. you will be fine
garth285 is offline
post #3 of 11 Old 01-30-2010, 10:44 AM
Bandana's Avatar
Send a message via Skype™ to Bandana
Hi Garth
A question, i read that you lowwerd the head by the gaskit right and also milled the head down right. Nice compresion to 14.2 : 1 a very well done job, but do you have issue on water temp.
Here our weather is a hot one around 30 Deg up and in hot days goes till 40 + Deg Celsius sometimes.
What you think if I had to that on an 09 model ?
regards Jo
Bandana is offline
post #4 of 11 Old 01-30-2010, 03:48 PM
KaTooM's Avatar
I have a thin on my 04, and intake kit cam. I had them both put in at the same time, more engine noise but better top end at the track.(like I needed it)
KaTooM is offline
post #5 of 11 Old 01-31-2010, 09:34 AM
tone.r's Avatar
i dragrace everyweekend and ride all day some time, you will be fine
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #6 of 11 Old 01-31-2010, 09:54 AM
nickalltogether's Avatar
It's crazy that bikes can run such high compression on pump gas, 14.2:1 is unheard of for a pump-gas car motor. What allows the compression? Do the cams bleed off a lot of the compression down low?
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #7 of 11 Old 01-31-2010, 11:49 AM
Speed Freak
garth285's Avatar
Originally Posted by Bandana View Post
Hi Garth
regards Jo
temps are slightly higher, but I actually dont even have a radiator fan on my bike until near summer time. The temps have slightly risen in the bike but not by much at all lmaybe 10 degrees at most and im just running regular 50/50 coolant
garth285 is offline
post #8 of 11 Old 01-31-2010, 12:40 PM
Bandana's Avatar
hi Garth
Thanks for the info.
A question guys, what is ambient temp there normally close to summer.
Bandana is offline
post #9 of 11 Old 01-31-2010, 12:54 PM
phastone's Avatar
The way it's been explained to me is because of the relatively small bore size of engines like ours. Also, our engines aren't moving a ton or two like 4-wheeled vehicles so they don't have the same kind of load on them.
phastone is offline
post #10 of 11 Old 01-31-2010, 03:44 PM
Maybe the short stroke rather than the smaller bore? I could definitely agree with you about the load though.
2005 Honda F4i-Red
Commuter stuff
thin head gasket ??????s supperdaddy Performance and Tech 16 09-27-2007 08:52 PM
Thin head gasket leak ninja3030 Performance and Tech 5 07-25-2006 09:45 PM
Thin head gasket MOSS10R Performance and Tech 17 12-12-2005 03:49 PM
Question On Thin Head Gasket... R1GSXRKILLER Performance and Tech 29 02-15-2005 05:31 PM
Thin Head Gasket????????? SP8 Performance and Tech 59 01-11-2005 02:34 PM
