Thin Head Gasket Size - Kawasaki ZX-10R.net
post #1 of 16 Old 08-06-2006, 10:23 AM Thread Starter
Guys,
Looking at the Kawi website I see there are three options for thin head gaskets for the '06 ZX10. They are: .50mm, .55mm, and .60mm. I'm curious what everyone is using or would recommend. My riding consists of a good amount of extended high speed highway runs on 93 octane gas.
I don't mind leaving a few horses on the table in exchange for not breaking anything so is it a matter of the thinner the better or something in between in the interest of reliability/longevity?
Thanks,
Damon
vdharris is offline
post #2 of 16 Old 08-06-2006, 10:11 PM
Originally Posted by vdharris
Guys,
Thanks,
Damon
I'm gonna install the .55mm
normjack is offline
post #3 of 16 Old 08-06-2006, 10:44 PM
there are actually 6 choices.. i went with 45mm..
11004-0022 Gasket-Head T=0.55
$16.92
11004-0023 Gasket-Head T=0.45
$16.92
11004-0026 Gasket-Head T=0.65
$72.58
11004-0034 Gasket-Head T=0.50
$16.92
11004-0052 Gasket-Head T=0.60
$16.92
deezuhl is offline
post #4 of 16 Old 08-06-2006, 11:06 PM
$16.92
$16.92
$72.58
$16.92
$16.92
Please tell us your results with the .45mm
normjack is offline
post #5 of 16 Old 08-06-2006, 11:06 PM
I have the .45mm installed in mine. And a spare on the shelf that I just checked the part number on. For sure the .45mm
Gunner is offline
post #6 of 16 Old 08-06-2006, 11:10 PM
results are in the avatar..
btw..thats under 1mile
deezuhl is offline
post #7 of 16 Old 08-07-2006, 08:50 AM
WOW thats stout. My 04 GPS @189 before having to shut down. That was stock gearing was still pulling. Was running with a buddy that had Head and cam package Busa.
Did you have to re-degree cams for piston to valve clearance?
normjack is offline
post #8 of 16 Old 08-07-2006, 09:13 AM
Piston to valve clearance is close Norm depending where you put the cam if you use the Kawi kit intake cam. For me and my style of riding I have my intake advanced to 105 and it's dead on .04 Piston to valve, BUT more importantly it has 205 static cranking pressure. If I advance the intake any more I'll need more room and a thicker gasket to lower the pressure some. It's on the edge in both cases. I wish my intake was advanced more for a street bike motor. Mid punch means more to me than all out top end. I'm in and out of the mid range constantly on any ride and seldom get a chance OR Place to run this bike top end.
Gunner is offline
post #9 of 16 Old 08-07-2006, 02:18 PM
yeah my bike doesnt have much down low but pulls like a freight train up top. with all the power my bike has right now you wouldnt beleive it doesnt come up off the ground in 1st at all with near stock gearing.. i dont know the cam #'s but i can tell you the top end is insane..
deezuhl is offline
post #10 of 16 Old 08-07-2006, 06:42 PM
We did the gasket, kit intake cam, and I ported the head.
Actually the bike is ALOT faster everywhere then it was with pipe and commander, when racing guys on 05-06 gixxer 1000's who have degreed cams, compression and more, also are good riders who race, thats when they will pull Deezuhls bike in 1st gear going from a 3000-3500 rpm roll, because the suzukis 1st gear ratio is much shorter than the kawasaki.
The bike with these mods and a good head make very good h.p.
This bike flies, its power is in the upper rpms.
we are geared 1/2 tooth taller than stock making it 198 mph gearing with the kit ECU to avoid hitting the limiter.
THE ICE MAN is offline
thin head gasket and cam degee ? oneradten Performance and Tech 3 02-10-2006 09:04 AM
Thin head gasket MOSS10R Performance and Tech 17 12-12-2005 04:49 PM
Zx-10 H.p. Cam And Thin Head Gasket max-out Parts, Gear and Accessories 1 06-17-2005 11:42 PM
Thin head gasket info.... R1GSXRKILLER Performance and Tech 121 03-21-2005 08:18 AM
Thin Head Gasket????????? SP8 Performance and Tech 59 01-11-2005 03:34 PM
