Techlusion DFO Installation help - Kawasaki ZX-10R.net
post #1 of 9 Old 04-21-2006, 10:44 PM Thread Starter
PatrickG's Avatar
Images: 15
Techlusion DFO settings???????
I am having a Techlusion sent to me for free, but it came off a z1000 not a zx10r. So, the directions are going to be different. They are the same thing but will be hooked up different.
Kawasaki Z1000 2003-06 ZX10R 2004-05
FI-1020
Does anyone have their settings for the dials?
PatrickG is offline
post #2 of 9 Old 04-22-2006, 03:11 AM
Sell it and get a PC, do it right. Doesn't answer your question, but it's what I'd do.
Birdman is offline
post #3 of 9 Old 04-23-2006, 10:29 PM
got 1 for my r1 and it only richens the mixture,not what I needed on the dyno. easy to install though.
hsmarc is offline
post #4 of 9 Old 05-02-2006, 02:55 PM Thread Starter
PatrickG's Avatar
Images: 15
I have installed mine and it was very easy to figure out.
I know that no one wants to admit having one of these TFI's. But if you do, you can "secretly" send me a PM with you dial/pot settings. To guide me in the right direction.
I won't tell anyone......
PatrickG is offline
post #5 of 9 Old 05-02-2006, 09:04 PM
Hahahaha Funny, but what if the right direction is to (and it will be in many parts of the map) remove fuel. What then?
Birdman is offline
post #6 of 9 Old 07-23-2006, 09:00 AM
Patrick,
Did you install the Techlusion on your Ten?
What were the results? Any conclusions?
Dave
Dave Bogue is offline
post #7 of 9 Old 07-23-2006, 01:12 PM Thread Starter
PatrickG's Avatar
Images: 15
Originally Posted by Dave Bogue
Patrick,
Dave
Dave,
Sure did!! I don't have it perfect, but it did take most of the ON/OFF abruptness feel from the throttle. And it pulls hard from 4,000 now instead of 6,000 rpms. I am pretty happy with it, but of course I got it for a steal. I haven't put it on the dyno with air/fuel sniffer yet. So, I can't tell you where it is running rich or lean. But overall I am satisified with the mod, I really wasn't looking for lots more HP, just smoother throttle control and maybe fill in the gaps in the fuel/air mixture.
PatrickG is offline
post #8 of 9 Old 07-23-2006, 03:03 PM
Sounds good!
Did you dial it in using "trial and error" or did you get some recommendations from www.Techlusion.com?
I have a stock 2006 (lowered and geared) that pulls very hard from the midrange, but I think is lean on the bottom half of the rpm range. Did you add fuel down low?
Best wishes,
Dave
post #9 of 9 Old 07-23-2006, 05:55 PM Thread Starter
PatrickG's Avatar
Images: 15
Sounds good!
Best wishes,
Dave
I have on 05' and I left it almost exactly the way they said to set it up on their website. I think I added a little more in the midrange but that was it, just because of the Yoshi pipe.
PatrickG is offline
Clutch installation with pictures. Vonstallin Performance and Tech 97 11-15-2015 05:44 PM
"How to" Power commander installation...lot of pictures lespaul66 Performance and Tech 3 03-12-2006 03:17 PM
"How to" Power commander installation...lot of pictures lespaul66 How To... 0 03-12-2006 08:32 AM
Frame Slider Installation racerman Performance and Tech 16 05-10-2005 08:01 PM
TRE installation help..... Ground Zero Performance and Tech 15 10-05-2004 05:27 PM
