tapping noise after long ride???? - Kawasaki ZX-10R.net
post #1 of 4 Old 03-21-2009, 06:23 PM Thread Starter
Everytime I ride my 04 ZX-10R for a long period of time it makes a tapping noise and its coming from the engine. It doesnt make this noise all the time, just when I ride for a long time. I thought it was a tappet or something but it kinda sounds like the timing chain. Anyone ever hear of this problem??????
ZXNUT is offline
post #2 of 4 Old 03-21-2009, 06:27 PM
I noticed a simular sound on my 05 after about 30 mins.
Meintez is offline
post #3 of 4 Old 03-22-2009, 02:42 PM
Gang Green's Avatar
Ok, fella. Tons of past threads about this one too.
Here is the first thing to try for the quickest simplest fix. Find a steep grade. After the bike is all warmed up approach the steep grade in 5th gear and chop the engine. Stop, pull the clutch in and roll it backwards. Slowly release the lever a few times, and you have now just readjusted your cam chain tensioner.
Or you can remove the cam chain tensioner and manually tighten it up with the flick of a screwdriver.
The factory tensioners sometimes wear out or break with a short lifespan. There are aftermarket ones that are simple to adjust and work great.
Hope this helps. You might try doing a search on here for past threads about this.
Gang Green is offline
post #4 of 4 Old 10-17-2009, 06:27 AM
Frogman's Avatar
Hey Gang green, as the rollback trick hasn't worked this time on my bike (it did before though), I've been thinking about removing the tensioner and adjusting it one click. What I'd like to know is, do I have to take the cover off the side of the motor and turn it over a couple of times to reset it or is it okay to just undo the cap to relieve the spring tension, then undo the mounting and push the plunger out click and bolt it all back up again - job done?
Any help in this would be greatly appreciated.
Frogman is offline
1st long ride minebymistake The Out House 15 05-21-2008 06:11 PM
First long ride impressions tommyttr The ZX-10R 34 07-06-2006 05:04 PM
06 10R ride report (long) booken The ZX-10R 12 03-27-2006 09:14 AM
First ride in a long while! Superbike1 The Out House 2 01-17-2006 03:47 AM
really long ride performancezx10r The ZX-10R 17 05-10-2005 08:48 AM
