Tanny ? - Kawasaki ZX-10R.net
post #1 of 10 Old 06-20-2010, 09:51 AM Thread Starter
tone.r's Avatar
Tanny ?
can down shifting hurt your shift forks?
LOL i meant to say tranny
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 10 Old 06-20-2010, 06:47 PM
redline659's Avatar
Down shifting? How? Like slamming through them without the clutch in? I guess I am somewhat lost?
To be a smart ash, yes it will hurt it. Once you have shifted to 6th gear you midas well sell it because its over.
But seriously its fine. Pull the clutch in and push down on the lever or up on it depending on how you have your lever setup.
redline659 is offline
post #3 of 10 Old 06-20-2010, 07:46 PM Thread Starter
tone.r's Avatar
down shifting at the dragstrip from 130+mph, i wasnt using rear brakes i was down shifting to slow the bike down, i was pulling the clutch in when shifting down.
Tone.R {checkmate}
tone.r is offline
post #4 of 10 Old 06-20-2010, 07:59 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
If you were just downshifting to slow the bike down and used the clutch then you should be fine, the 10's have a pretty damn good slipper clutch just for that very reason, and so the rear doesn't lock up in the process either of course.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #5 of 10 Old 06-20-2010, 08:13 PM Thread Starter
tone.r's Avatar
I just put a new shift fork in tranny but now its jumping again in 2nd gear, the only thing i done sense the new shift fork was downshifting when racing, looks like i will be pulling the motor again DAMN.
Im going to check the shift drum when i open it up again
Tone.R {checkmate}
tone.r is offline
post #6 of 10 Old 06-21-2010, 12:18 AM
redline659's Avatar
Have you put in upgraded shift shafts yet? Its cheap insurance. Its likely they are bent and this is what is causing the issue. I think brock sells them. They will deflect and then come back tp strait whereas the stock ones will deflect and stay. I know you drag your bike alot as well. Have you investing into a good cut trans as well? The shift forks in the 10 are pretty good stock its the shafts that tend to become the issue
post #7 of 10 Old 06-21-2010, 06:32 AM Thread Starter
tone.r's Avatar
I did replace the top shift shaft when i replace the shift fork, when i open it back up im going to get the tranny back cut, and i think im going to replace the shift-drum to be on the safe side.
Tone.R {checkmate}
tone.r is offline
post #8 of 10 Old 06-21-2010, 08:58 AM
redline659's Avatar
Replaced it with what? Stock?
post #9 of 10 Old 06-21-2010, 04:22 PM Thread Starter
tone.r's Avatar
yep stock, after talking to some tranny guys its looking like gears and shiftdrum.
Tone.R {checkmate}
tone.r is offline
post #10 of 10 Old 06-21-2010, 05:23 PM
redline659's Avatar
Usually the dogs get worn out and thats what causes it to jump out of gear. Replace the shift shafts with good ones
Lower tanny gear tone.r Performance and Tech 4 01-19-2010 10:00 PM
WTB lower 1st tanny gear tone.r Wanted: Buy or Trade 1 10-28-2009 09:28 PM
