Taillight wiring - Kawasaki ZX-10R.net
post #1 of 16 Old 04-02-2008, 08:33 PM Thread Starter
hollywood99's Avatar
Taillight wiring
i have the clear alternatives integrated for my 05 10r...i was wondering if anyone wuld know which wire is the one for the running taillight. i am hooking up a license plate light. so i need to kno which wire to splice into
thx guys n gals
hollywood99 is offline
post #2 of 16 Old 04-02-2008, 08:59 PM
Orange Juice's Avatar
If you don't have a digital multimeter, you can use the CA integrated tail light as a test light. Maybe an actual owner of the CA integrated tail light installed in a slow '05 Magma Red ZX-10R will speak up...
Orange Juice is offline
post #3 of 16 Old 04-02-2008, 09:04 PM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
I " Slow Magma one " am not in front of the junk right now. Won't be until Saturday. Anyhow there's two wires one on each plug. One wire is gray and the other might be green/yellow. You can double check this bye taking the exposed wire(s) and putting them on the top of the pin. If you get light, there ya go. If not then it is not it... Volaaaaaa
Please paint your Magma. The 05 Pearl jawn is the slowest one of them all. Believe me I know. Now we all know that the 10 is the slowest of all liter bikes and is no Gixxer, so let's fall to our knees in shame
OneSLOW10 is offline
post #4 of 16 Old 04-02-2008, 09:06 PM
ducatiryder89's Avatar
Images: 21
Don't splice into the wiring!!!!!!!!!!!!!!! Use the factory connector from the stock fender and soider the clear alternatives wire onto the section of wire and connector coming from the fender. That way whenever you want to pull the tail off for whatever rason you don't have to cut the wiring.
ducatiryder89 is offline
post #5 of 16 Old 04-02-2008, 09:13 PM
Images: 21
When you take the fender off you had to unplug three connectors. One for the license plate light and one for each turn signal. Cut the connectors off the fender leaving about 6 inches of loom. Remember what color goes to what side and I think the black one is for the license plate light. Soider the wiring coming from the CA light to each connector. Much cleaner and OEM looking. I the green connector is right turn and gray is left turn with a black connector for the license plate light.
post #6 of 16 Old 04-02-2008, 09:14 PM
OneSLOW10's Avatar
Some like to splice. I however did not.
I sexually have the wire installed directly into the pin. Easy as pie :). No tail removal issue and you can button it up right back in the oem rubber cover.... One more thing. There is only 2 wires ( obvious ) for the CA tail. Each hot turn sig wire installed into the correct oem wire power the tail..
post #7 of 16 Old 04-02-2008, 09:17 PM
OneSLOW10's Avatar
you want a cleaner more oem look? you should! to achieve that in this case it requires no cutting. I wouldn't recommend cutting anything. No need to. that must be riced jdm. sorry my English isn't to good and i am not wearing my asics.
post #8 of 16 Old 04-02-2008, 11:00 PM
Images: 21
Before you try to be funny I'm talking about the connectors that come of the stock fender that you are not using anyways. I'm not talking about any wires that come off the main harness.
post #9 of 16 Old 04-03-2008, 05:21 PM
OneSLOW10's Avatar
The OP can do whatever he wants. Hack it up, make it lQQk sex, doesn't matter. But my response about what you wrote is if your providing that oem [ " clean is " ] the way to go, which I agree with you, then why does he want to butcher/cut anything? He might return it back to stock and sell it some day. Who knows what the future holds. Or he could realize that since the CA draws an extreme amount of power and slows the 10 down even more, he will at that point want to take it off and use it as target pratice
that is all
post #10 of 16 Old 04-03-2008, 05:37 PM
JOSHUAZX10's Avatar
Images: 7
Send a message via Yahoo to JOSHUAZX10
How does one install a wire sexually ??
JOSHUAZX10 is offline
taillight not working snoopnoon Performance and Tech 4 05-05-2006 11:19 PM
Velcro Taillight? zxtener The Out House 10 02-23-2006 12:18 PM
taillight sweetride10r Parts, Gear and Accessories 5 12-12-2005 01:10 AM
Taillight Integrator Fever The ZX-10R 13 08-01-2004 03:36 PM
Need Help With Wiring or Wiring Diagram for 2004 ZX-10 cashes41 The ZX-10R 0 05-21-2004 04:24 PM
