taillight not working - Kawasaki ZX-10R.net
post #1 of 5 Old 05-04-2006, 11:10 AM Thread Starter
hey guys, heres the deal. A while back i was hit from behind and severed the connecter to the taillight. Anyways i bought a new taillight and replaced all the body work and put individual female spade connecters on the wires. I hooked those up to the light and things worked perfectly. Then i had to take the tail apart for another reason and now i put it back together the taillight will no longer work. Before i get too many questions i will try to post as many things i have tried as i could.
1) checked for power across the red wire and the frame, (12.7 volts). then checked for power across the red and black and yellow wire that were suposed to go to tail (12.7 volts). so i am getting power going into the tail and ground is good.
2) checked for open in te taillight or short, neither, getting like 5 Mohms of resistance accross power and ground
Just to humor me would somody double check that i have the right sequence of wires going into the taillight.
looking top down, from the rear of the bike looking to the front, left to right going into the tail i have red, black/yellow, blue
If sombody could double check that would make me more at ease its not somthing stupid.
Next is open for suggestions... oh BTW i ordered a new taillight off ebay, and tried that one, again not working. What are the chances that two taillights are dead??
snoopnoon is offline
post #2 of 5 Old 05-04-2006, 12:15 PM
eric's Avatar
tail light from left to right is (red), (black/yellow), (blue/red). i tried downloading the wire diagram but it wont let me.
eric is offline
post #3 of 5 Old 05-05-2006, 01:00 PM Thread Starter
ok so wireing is right.. nobody have any other idea's?
post #4 of 5 Old 05-05-2006, 01:47 PM
eric's Avatar
check the fuse just to be safe. does your brake light, rear turn signals ,and plate light work.
eric is offline
post #5 of 5 Old 05-05-2006, 10:19 PM Thread Starter
OK after hours of diagnostics i figure what the hell, the light seemed busted anyways so may as well try it. I put black/yell wire all the way to right, blue middle and red left..bblliiiinnngggggg... there goes the light. Working perfectly. The manual is WRONGG!!!!!!!! this should be noted and sent to kawi
taillight sweetride10r Parts, Gear and Accessories 5 12-12-2005 12:10 AM
Flatout web site working!!! NWZX10 The ZX-10R 8 04-08-2005 11:50 AM
Wow! Got my integrated CA taillight already! El Diablo The ZX-10R 21 02-25-2005 10:07 AM
How to get taillight out of ZX10R steves87 Performance and Tech 14 01-11-2005 09:03 AM
Taillight Integrator? nolaZX10 The ZX-10R 2 06-28-2004 08:42 PM
