Gen 5: 2016- Tach signal for the dyno - Kawasaki ZX-10R.net
post #1 of 7 Old 07-30-2019, 08:41 AM Thread Starter
Husabuse's Avatar
Hi!
I’m going to get the bike properly set up on a dyno, and I need to find the tach signal for the dyno.
Is there a way that doesn’t involve removing the airbox?
Rgds
/J
Husabuse is offline
post #2 of 7 Old 07-30-2019, 11:08 AM
Kawasaki Brad's Avatar
What gen is your bike?
Anything can kill you. Pick something fun.
Kawasaki Brad is offline
post #3 of 7 Old 07-30-2019, 01:08 PM
nakedinseattle's Avatar
Generally the sensor is an alligator clip from the dyno that clips onto usually an ignition wire above a coil pack and is usually accessed from the side. To make it easier for the tuner, remove one or both side panels
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #4 of 7 Old 07-30-2019, 01:47 PM Thread Starter
Husabuse's Avatar
Gen 5
Husabuse is offline
post #5 of 7 Old 07-30-2019, 04:24 PM
Any one of the stick coil leads will do which go back to the ECU individually.
Cylinder 1 Black
Cylinder 2 Black with Red Stripe
Cylinder 3 Black with Orange Stripe
Cylinder 4 Black with Green Stripe
Last edited by Kawasaki Brad; 07-30-2019 at 05:20 PM. Reason: Corrected cylinder 3&4 colors.
post #6 of 7 Old 07-30-2019, 04:33 PM Thread Starter
Husabuse's Avatar
Cylinder 1 Black
Cylinder 3 Black with White Stripe
Cylinder 4 Black with Orange Stripe
Sweet, just what I hoped for! Which one of the three connectors would I be looking at...?
Rgds!
/J
Husabuse is offline
post #7 of 7 Old 07-30-2019, 05:22 PM
Rgds!
/J
DOH! I was originally looking at the diagram for the gen4. So I removed the picture and changed the wording (cylinder 3 and 4) to reflect the proper colors. 1 and 2 did not change. It's on the left most harness (when you're sitting on the bike) kickstand side.
Only reason I caught the mistake was when you mentioned there were 3 harnesses. Gen 4 only has 2. Sorry about that.
