switching (swap) forks question - Kawasaki ZX-10R.net
post #1 of 8 Old 01-11-2010, 11:35 AM Thread Starter
the_angry_samoan's Avatar
Images: 11
are the lower OD on the tripple clamps on all brands of japan bikes the same?
if i wanted to a zx10 front end on another bike like a honda -- it should work -- just make wheel spacers for the front wheel and change the bearings to mach the new axle and have a top clamp made to fit the OD of the top of the fork -- i know those are different from brand to brand
has anyone done this swap here --- i know of people ding this
DRGENESCOTT.COM / PASTORMELISSASCOTT.COM
the_angry_samoan is offline
post #2 of 8 Old 01-11-2010, 11:40 AM
Speed Freak
garth285's Avatar
it varies from bike to bike but some are interchangeable
garth285 is offline
post #3 of 8 Old 01-11-2010, 11:46 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
Indeed, some are interchangeable all will work in some sense or fashion.
nothing some attack triples cant fix if there is an issue with the difference in fork diameter, and the stock triples not beiing used.
otherwise could have some sleeves made..
What year forks (donor) are they and what bike they going on?
might helpt to get you started, also fork length can be an issue.
jdgun_13 is offline
post #4 of 8 Old 01-11-2010, 11:46 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
There are some variables, on certain bikes the bottom diamater is different than the top, vs other bikes, in other words the clip on area is 50MM on alot of bikes but the lower triple clamp area is different diamater. You can modify most triple clamps fairly easy, the steering stem is pressed in and you can get custom steering stems or machine sleves, etc. I am fairly confident looking at your creations so far, that you should be able to make something work.
9R to 10R is offline
post #5 of 8 Old 01-11-2010, 08:23 PM Thread Starter
Images: 11
ok -- i want to update my RC51 SP2 to an 09 front end -- i want to use the 09 R1 front end cuz it is light and i want the 6 piston calapers -- and i kno some say they are junk and some say they work great after U change the roder out
i already have a carbon front wheel that i want to keep witch is honda -- now with that said -- from roder to roder on the R1 is 133mm and on the RC51 is 142mm will that be a problem -- i went th the yamaha shop to take a measurment on the lower leg of the fork and i can't get a good shot at it
post #6 of 8 Old 01-11-2010, 08:28 PM Thread Starter
Images: 11
thanx Bro -- have U seen the new pic of my RC51? --- i'm getting radial mounts made for the 6 piston calipers right now for my bike -- but i would like to use the R1 forks -- U kno the yamaha owns ohlins
post #7 of 8 Old 01-11-2010, 08:42 PM Thread Starter
Images: 11
hey check out the clip on you tube
post #8 of 8 Old 01-11-2010, 08:55 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Looks bad ass, and Ohlins bought itself back from Yamaha now I believe. Donb't quote me on that, but I remember hereing that.
Another swingarm swap question... 1st gen to 2nd gen swap RITCHYRITCH The ZX-10R 2 10-21-2009 03:05 PM
a question for those that have done the caliper swap ash01s2001 Performance and Tech 7 09-12-2009 12:53 PM
Help! Caliper swap question. BrandensDogs Performance and Tech 21 07-30-2008 12:16 AM
ZX-14 brake swap question Alien10 Performance and Tech 15 10-28-2007 11:05 PM
04 Forks, 06 wheel: bearing swap not possible? Vonstallin Performance and Tech 4 06-29-2007 04:09 PM
