swingarm swop
770 views 3 replies 4 participants last post by  nickalltogether
#1 ·
Hi everyone,
Does anybody know if a 08/09 zx10r swingarm will go into an 05 zx10r frame? If so,are there any modifications needed to the suspension mount/linkage to line things up.:cool:
#3 ·
indeed there are threads and different thoughts on the set-up.
guessing you are using a stock shock as well, as most aftermarket require the swingarm to be clearanced.
but i like many others are using the 05/06 zx6r shock linkage and dogbones with the swingarm.
Will have to adjust the ride height that is for sure.
