swapping out a cam....do i have to redegree?? - Kawasaki ZX-10R.net
post #1 of 3 Old 06-16-2011, 09:01 PM Thread Starter
ke2012's Avatar
Hello all.....quick question....I want to install a pinned 04 intake on the exhaust side of my 08, right now i have the cams alreakdy installed degreed at 109/110. My question is can I just zip tie the sprocket to the timing chain, mark the sprocket, remove it, install it on the pinned cam, drop it back in, drop it in and be good to go??? Thanks in advance.
ke2012 is offline
post #2 of 3 Old 06-16-2011, 09:05 PM
Gen 5 Now!!
08zx10rny's Avatar
i would redegree them just to make sure. would suck to take a shortcut and wind up either not the numbers you wanted or valve damage if its off a little. id just take the extra time and do it the right way. just my
GEN 5!!!
08zx10rny is offline
post #3 of 3 Old 06-16-2011, 09:24 PM Thread Starter
ke2012's Avatar
Good point
ke2012 is offline
Gen 3: exhaust swapping slowzx10r Performance and Tech 2 03-22-2011 06:05 PM
Swapping frames jblaze Performance and Tech 36 05-06-2009 06:47 PM
swapping salvage frame zxcamino General Motorcycle Discussions 6 11-20-2008 08:54 PM
Swapping Out Crank Cases????? SP8 Performance and Tech 11 09-04-2008 08:31 AM
swapping wheels motomike Performance and Tech 11 05-15-2008 08:32 PM
