Swapped an 05 motor to my 04, bike won't start up - Kawasaki ZX-10R.net
post #1 of 20 Old 03-15-2010, 11:41 AM Thread Starter
Costas's Avatar
Send a message via AIM to Costas
The motor on my 04 recently grenaded itself when the generator came apart (see https://www.zx-10r.net/forum/showthread.php?t=79314), picked up an 05 motor from a friend that was running when he took it out his bike, but it won't start up on my bike now.
From the looks of it, it seems like it's most likely the coil harness, but that was working fine on my 04 and it was swapped over to the 05. The coils were changed from the old motor and put in the 05, and it has new spark plugs, but 1, 2, and 4 aren't getting any spark. If you disconnect it there's no spark at all, then when you connect it, only one of them gets a spark. The only other issue we came across was the battery was dead (read 11.9 volts) and it was charged overnight and the charge didn't increase.. but then it magically shot up to where it's supposed to be.
Is there anything else it could be before I order a new coil harness?
Costas is offline
post #2 of 20 Old 03-15-2010, 12:23 PM
Are you getting any codes on the FI light?
anaxagoras1986 is offline
post #3 of 20 Old 03-15-2010, 12:56 PM Thread Starter
Costas's Avatar
no FI light, fuel pump primes, normally too
Costas is offline
post #4 of 20 Old 03-15-2010, 02:16 PM
Assuming you already checked to make sure all of the connections are good... Reseat any of them? Will it pull any codes when you ground the diag lead?
Before getting s new harness, I would check that the pins on the ECU have continuity to the leads on the coils. The service manual should give you the wiring codes to map which pin goes where.
post #5 of 20 Old 03-15-2010, 02:50 PM
wrisktakerz1's Avatar
can someone pm on how to get fi codes and where to diagnose them
wrisktakerz1 is offline
post #6 of 20 Old 03-15-2010, 04:07 PM Thread Starter
Costas's Avatar
hmm.. the ECU was never touched, so i don't know why that would be giving me problems
Costas is offline
post #7 of 20 Old 03-15-2010, 06:57 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
That's what i was going to ask....if you'd swapped out the entire harness AND ecu from the 05' motor? i JUST saw a link on here this weekend about the FI codes for our gen.......... lemme see if i can find it or if i take too long then i'm sure using the ol' "search" will help you out. hope ya get it figured out buddy..i fuggin HATE electrical issues!!!!
TMY10ER is offline
post #8 of 20 Old 03-15-2010, 07:40 PM
browserzx10's Avatar
if you have a power commander make sure it has been wired in correctly, belive it or not it can be pluged in wrong,
browserzx10 is offline
post #9 of 20 Old 03-16-2010, 08:33 AM
I'm not saying the ECU, I'm talking about the wiring. Checking to see if the pins on the ECU plug (the chassis wiring loom, not the ECU itself) have continuity to the plugs on the coils.
post #10 of 20 Old 03-16-2010, 10:44 AM
beenthere's Avatar
all of the above sugessions and make SURE you have a good battery
beenthere is offline
HELP!!! Bike will not start.... BornSinner Performance and Tech 3 03-13-2009 12:18 AM
bike won't start slayer Performance and Tech 2 09-08-2008 08:16 PM
bike won't start russell Performance and Tech 12 03-15-2008 11:50 PM
Need Help bike won't start CMG Performance and Tech 2 09-26-2007 11:09 PM
Bike won't start DareDevil The ZX-10R 34 04-22-2006 08:50 PM
