Suspension question - Kawasaki ZX-10R.net
post #1 of 11 Old 01-03-2010, 12:52 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
Suspension question
Hey guys..I got a 06 10r now and i just bought a left over 08..My question that sence i spent $1000 gettin my front and rear suspension revalved and resprung can i just switch over the complete suspension or can i get the internals and springs switched to the 08??
I would do some research but my lil crack berry screen aint that big and im not gonna be home for a week..
craig_sez is offline
post #2 of 11 Old 01-03-2010, 01:14 PM
All show and all go 10r
JLG0987's Avatar
I don't know alot about suspension but I'm pretty sure you could swap the suspension but, the setting would probably be wrong. The 08 is weighted differently and would throw off your setup.
JLG0987 is offline
post #3 of 11 Old 01-03-2010, 01:48 PM
Supercharged Mod
I don't think it will be a constructive thing to do; too many minor differences.
GoFaster is offline
post #4 of 11 Old 01-07-2010, 05:36 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
I was kinda thinkin the same things....Just figured where i am a lil bigger than most guys around here that ride(im 45 yrs old,225 lbs with out gear)and the internals are a set down from race internals..Also figured i could save a buck on a suspension mod for my new ride..
I cant even compare side by side yet..My new ride is 3 hrs away at a dealership and my garage is full now..
post #5 of 11 Old 01-07-2010, 05:45 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
MAGIC..pm sent..
post #6 of 11 Old 01-07-2010, 06:46 PM
dirt ninja's Avatar
Images: 9
I believe the front fender from the 08 wouldnt fit on the 06 forks. You'd have to check for yourself. Id just buy new springs for the front and get a new or used rear shock and call it a day. I wouldnt bother with all the revalveing if you arent tracking the bike.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #7 of 11 Old 01-08-2010, 12:06 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
tks for the help guys.....What about just swapping the internals??
post #8 of 11 Old 01-08-2010, 12:50 PM
TENN10's Avatar
Images: 145
Originally Posted by MagicMavis View Post
I have the official 08 Kawasaki suspension manual in .pdf from. PM me a email if you want it. Not sure how much in there to help anyone as I switched over to Ohlins and never read it in depth.
I've never seen or heard of that manual.
I'll PM you my email address in a bit.
TENN10 is offline
post #9 of 11 Old 01-08-2010, 01:02 PM
TENN10's Avatar
Images: 145
The front springs on the 08 are really stiff. Perfect for an aggressive 225 lb. rider. I weigh the same and have (i think) 7 lines of pre-load showing.
My suspension is stock at the moment and set up by Ken with Superbike Suspension at the track.
As far as swapping the internals, you should ask someone who knows for sure. Either the person that originally installed them or I would be willing to bet Superbike Suspension could help you out. 815-583-3600 or there website is http://www.superbikeitalia.com/
If I'm not mistaken, they sent me an e-mail saying they are discounting suspension work this month.
TENN10 is offline
post #10 of 11 Old 01-08-2010, 01:32 PM
Ninja187's Avatar
The forks on the 08 are great, no need for swap up front. The rear on the other hand needs work, anything other than stock will be better. Save your coin and leave the forks alone. .02
GEN 4: Brembo HP calipers, Brembo HP T-Drive Rotors, Brembo RCS master cylinder, Fren Tubo SS lines, re-valved Ohlins damper, Ohlins TTX shock, Yoshimura case covers/frame sliders, Yoshimura 3/4 R77D Ti exhaust, BMC filter, Puig DB, Renthal Clip ons/sprockets, attack rearsets, Guhl flash, kawi kit throttle, Ballistic EVO2 8 cell, Annitori RL quick shifter, Dunlop rubber.
Ninja187 is offline
suspension question... norm15 Track 17 03-24-2009 08:33 PM
Suspension question about forks Costas Performance and Tech 6 03-17-2009 04:20 PM
Suspension Tuning - Question tr69mustang Performance and Tech 8 02-07-2009 04:58 AM
Suspension/geometry question booken Performance and Tech 19 09-11-2006 06:31 PM
suspension setting question S.ga.rider The ZX-10R 6 06-01-2006 11:56 AM
