suspension mods WORK ! - Kawasaki ZX-10R.net
post #1 of 7 Old 05-24-2007, 07:50 AM Thread Starter
A few weeks ago I went to a local shop that is operated by a sponsored road racer.
I explained to him that the bike felt sluggish when trying to enter corners, and when transitioning from left to right ...
He suggested a height adjustment and offered to raise up the rear...
So, they added a spacer to the rear shock ( a simple washer just like the stock one ) and that increased the height by 8 mm.
Now the bike handles much better, feels much lighter than before, It doesn't feel like I have to lug it so hard to make it change directions and even under power it does it much smoother !
Anyway, if anyone has this same problem then I suggest doing the same thing =)
GOOD LUCK !
fordfasterr is offline
post #2 of 7 Old 05-24-2007, 08:05 AM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
Congrats! Nothing better'n a bike acting the way she should!
James 3:7,8
hillcountry10r is offline
post #3 of 7 Old 05-24-2007, 10:10 AM
bulletr1's Avatar
Send a message via Yahoo to bulletr1
That was a good mod. I did that myself also.
PC Frame, Swing Arm, Wheels. Gold Rear Sets, Chrome Heel Guards, Factory Pro. Vel. Stacks, PCIII, K&N Air Filter, Full Akra. Exhaust System, 525 DID Gold MVXZ Chain, HID KIT HI & LOW BEAM (6K), 1/5 Throttle Conversion, Ivan's Block Off Kit,TRE & Servo Elim. Air Box Mod, Stainless Steel Braided Lines, Blue Custom Gauge Panel, InterNatrix Paging Security Sys., Michelin Pilot Powers Tires, Barnett Clutch Springs, Custom In/Ex Cams by Web Cams, Milled Cylinder Head. 173.7RWHP
bulletr1 is offline
post #4 of 7 Old 05-25-2007, 03:38 AM
Mustard's Avatar
so does this now mean you have 2 washers in there? Anyone know how this works with a taller profile 190 (can never remember if its 50 or 55)
Once i thought more than two strokes was masturbation. Now I realise that 4 feel better, and who am I to argue with my feelings.
05 Black/white road/track zx-10r. Race fairings with stock headlight custom blinkers, Brembo MC, HEL braided lines, Toby dampner, Mustard Block-off plates, plugged airbox, Mustard Heel guards, Mustard Ram-air tube support, custom flip-up rear fender eliminator, custom rear fender, custom seat cowl, corsa 111's.
Mustard is offline
post #5 of 7 Old 05-25-2007, 06:43 AM
If you run the 55 its taller and will offer some of the same benefit.
Steering stabilizer becomes even more important.
Much the same affect get be accomplished by lowering your front in the triples in 2mm incriments.
Many bikes from a generation or two back befefit from a whopping 10mm drop up front!! It can make that big of a diffy!!!
Remember when you increase the aggressive stance you sacrifice stability. So you can flick and fling in the lower speed chicanes but could wobble in the sweepers.
06450F is offline
post #6 of 7 Old 05-25-2007, 09:07 AM
drkramm's Avatar
yea i dropped my 04 636 7mm on the front and it was awesome then i tried another 2mm and i couldn't accelerate on the highway with out the bike wiggling everywhere so i raiseit back up and kept it at 7mm
im waiting till i get new tires till i really start messing with mine
"Once you've tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been and there you long to return."
drkramm is offline
post #7 of 7 Old 05-27-2007, 10:20 PM Thread Starter
the bike is completely stable in all types of corners so far..
On some long sweepers I can hit the high obi-wan-seventies with no problems, while on the tighter ones I can go to max lean and still pull through with great speed and stability.
PS: I love the pirelli diablo tires too !!!!!!!!!!
Suspension Work. dean2847 Performance and Tech 4 04-17-2007 09:32 AM
Suspension work Older Guy Performance and Tech 28 11-05-2006 10:33 PM
Suspension Work Help monte11974 Performance and Tech 5 10-06-2006 08:32 AM
head work / engine work rrdble Performance and Tech 3 01-04-2005 08:27 AM
Suspension Mods. KWAK10R The ZX-10R 7 04-24-2004 02:00 AM
