Surging beyond 9k - Kawasaki ZX-10R.net
post #1 of 14 Old 05-19-2011, 01:00 PM Thread Starter
DanHor7's Avatar
Surging beyond 9k
I just threw a headlight in my race plastics and took the bike for a spin for the first time since I tucked the front at the track.
I rolled on full throttle in 2nd gear and it started surging. At first I thought the tire was spinning and grabbing intermittently but then it did it again in 3rd.
I slowed down to about idle with it in 4th and rolled on full throttle and it started surging [like I was momentarily closing the throttle] around 9k and continued surging on up to the red line.
The only crash damage (APPEARS) to be cosmetic, other than a little oil leak.
Any ideas?
Also it seems to be idling fast (2k) and rough like it's missing or weak on 1 cylinder.
http://www.youtube.com/watch?v=H_8vE...0&feature=plcp
Don't limit yourself to your false perseption of what you're capable of and just do what you dream. It's easier than you can immagine.
DanHor7 is offline
post #2 of 14 Old 05-19-2011, 01:16 PM
Hmm, sounds pretty odd. I would double check any wires that are on that side of the bike just to make sure they didnt get damaged. Other than that, maybe someone that has a little more knowledge can chime in.
Scott10r is offline
post #3 of 14 Old 05-19-2011, 01:24 PM Thread Starter
DanHor7's Avatar
The only thing I've done since the crash is wash off the dirt with a pressure washer, fill the fuel tank(yesterday) and ride it 6 miles (today).
You would think everything electrical would be dry by now unless water got in where the oil is coming out. I don't know what is behind those 2 damaged engine cases.
I was thinking it was possible that it sucked some air while on it's side in which case I would expect it to take care of it's self just by riding it.
DanHor7 is offline
post #4 of 14 Old 05-19-2011, 08:16 PM Thread Starter
DanHor7's Avatar
Tor it down and pulled a plug.
The bike has 17,000 miles. The plugs are probably the originals so I'll be replacing them.
The bike was running like a mofo 6 miles ago, I low sided and now it's cutting out over 9k so I'll be shocked if it's due to a wear item.
Any ideas?
DanHor7 is offline
post #5 of 14 Old 05-21-2011, 08:06 PM Thread Starter
DanHor7's Avatar
I've replaced the plugs, serviced the air filter, changed the oil and when I started it there was a red light flashing on the right and (fi) flashing on the lcd display.
I didn't notice it before but that doesn't mean it wasn't there. Find it hard to believe I wouldn't have noticed a flashing red light though. Especially considering the attention I was giving the instrumentation as soon as I noticed I was having problems.
DanHor7 is offline
post #6 of 14 Old 05-22-2011, 07:23 PM Thread Starter
DanHor7's Avatar
After extensive internet searching and begging around for information in places like ZX10r.net I've found that no one has any idea what might be wrong with my bike so I'm going to give it away to the neighbor kid and get a Honda.
DanHor7 is offline
post #7 of 14 Old 05-23-2011, 02:17 PM Thread Starter
DanHor7's Avatar
Originally Posted by Screw it_I'll say it>>> View Post
video to fast to tell
That video was from when it was running fine.
Try this one.
I just found that I'm getting an error code (13).
Anyone know what that indicates?
DanHor7 is offline
post #8 of 14 Old 05-23-2011, 02:45 PM
K-Litre's Avatar
Dude,
On page 41 of the Service Manual, it says:
○Be sure to connect the air temperature sensor connector.
When the ignition switch is turned ON with inlet air
temperature sensor connector disconnected, the ECU
detects the service code 13. Then the ECU starts the
fail-safe (see Self-diagnosis Outline in the Fuel System
(DFI) chapter). In this case, the engine vacuum synchronization
can not be inspected correctly.
Sounds like something got knocked loose.
K-Litre is offline
post #9 of 14 Old 05-23-2011, 06:01 PM Thread Starter
DanHor7's Avatar
Thanks man! I'll check it out.
Much appreciated
DanHor7 is offline
post #10 of 14 Old 05-23-2011, 06:50 PM
You still haven't replaced the damaged bolts on the starter gear cover?
I would fix the leaks and only then ride the bike. IMO leaking oil = pretty unsafe thing.
a.leopard is offline
Should I be concerned with slight surging at idle? den33 Performance and Tech 10 09-11-2010 01:11 PM
Help! Brand New 2009 ZX-6R Severe Throttle Surging! Proteus The ZX-10R 8 07-21-2010 04:31 PM
06' 10r surging, Sounds like it dropped a cyl... Mr9two9 The ZX-10R 2 03-01-2010 12:58 PM
2006 two brothers exhaust surging rayszx10r Performance and Tech 2 09-11-2006 07:44 PM
