Stupid question... Power Commander related - Kawasaki ZX-10R.net
post #1 of 4 Old 07-29-2008, 11:04 AM Thread Starter
CheeseHeadNinja's Avatar
How do I remove my power commander? Without taking the tank off and all that crap. Or can I set it to "OFF" or something so that it runs stock? I don't want to lose my old map, but I want to run it stock temporarily.
So is there any way to run it stock or remove it easily? I looked in the instructions and it just says that i can "use the 9v power adapter to remove the PC from the bike"
CheeseHeadNinja is offline
post #2 of 4 Old 07-29-2008, 11:27 AM
Images: 28
If you have a laptop just plug it into the powercommander and save your current map. Then clear the map out of the Powercommander. This will set all the cells to 0% which is the same as stock. You can also use a home computer if you can get the bike close enough to it. If you dont have any type of computer then you will have to remove the tank to unplug the powercommander harness from your bike.
roland5color is offline
post #3 of 4 Old 07-29-2008, 12:27 PM Thread Starter
Damn, that's what I was afraid of. The manual made it sound like it was a simple thing to "remove the PC from the bike to your computer."
thanks
post #4 of 4 Old 07-29-2008, 03:00 PM
Images: 28
Yeah only way to get the PCIII out to take it to a home computer is to do what I have already told you. The wiring harness has no quick disconnect.
Stupid (or not so stupid) question re: brake lines wicked The ZX-10R 8 12-28-2007 06:53 PM
maybe this is a stupid question but Ill ask anyway teamgreen Performance and Tech 9 12-27-2007 03:35 PM
That stupid question again. ninja_12r2000 The ZX-10R 1 07-23-2007 10:27 AM
Might seem like a stupid question griffenzx10 Performance and Tech 3 11-02-2006 09:04 PM
Stupid question #85 Ctchme The Out House 3 12-15-2005 07:46 AM
