Stupid fairing tabs - Kawasaki ZX-10R.net
post #1 of 4 Old 01-17-2010, 12:34 AM Thread Starter
Send a message via AIM to wickedsprint
Stupid fairing tabs
Removing the lower fairing...broke one of the stupid main fairing tabs...got pissed off...removed the other 3...now..the lower is much easier to remove...that is all.
wickedsprint is offline
post #2 of 4 Old 01-17-2010, 08:11 AM
RDLYN13000's Avatar
Images: 38
Yup ya gotta be easy with them plastics, it doesn't take much to break em...
RDLYN13000 is offline
post #3 of 4 Old 01-17-2010, 08:19 AM
Diveslob's Avatar
Done the same on the tail unit, used a PVA glue to hold it together, then fiberglassed the back of it, sanded it back to tidy back up, pain in the arse!
Diveslob is offline
post #4 of 4 Old 01-18-2010, 01:02 AM
bugman53's Avatar
the best thing for plastic is a 2 part chemical( not epoxy) that is called plastic weld. It works great. It melts into the plastic and bonds stronger then the base plastic. I attached the tabs with it and then file it back smooth so you can not tell it was ever fixed.
autozone had it at 5$ a tube
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
cracked tailpiece tabs repair question on 04 zx-10 kevenater The ZX-10R 9 03-05-2009 11:09 AM
Stupid (or not so stupid) question re: brake lines wicked The ZX-10R 8 12-28-2007 06:53 PM
Stupid Crash. Stupid mistake. Gang Green The Out House 6 10-26-2007 04:27 PM
'04 tail section tabs? HPower The ZX-10R 13 03-14-2007 10:02 PM
A stupid fairing/slider questionq king-tony The ZX-10R 10 03-21-2005 09:46 PM
