Stripped Phillips Head...NEED HELP!!!!!! - Kawasaki ZX-10R.net
post #1 of 7 Old 12-27-2005, 06:59 PM Thread Starter
IcePick06's Avatar
Ok guys, I'm trying to install these CA lights. I'm trying to remove the seat latch assembly and one of the phillips head screws WILL NOT COME OUT. I tried to use my Dewalt gun after unsuccessful attempts with a regular screwdriver and it stripped the freakin' screw. Now I've made the screw head practically round and I don't know how to get it out. PLEASE HELP ME OUT!!!!
IcePick06 is offline
post #2 of 7 Old 12-27-2005, 07:09 PM
if u have a little cut off wheel, you can cut a straight notch into the head, and then use a flathead screwdriver to remove it, if not you can buy a screw extracter, i have one from sears i think, and it works all the time
good luck
ORANGE10R is offline
post #3 of 7 Old 12-27-2005, 07:29 PM Thread Starter
IcePick06's Avatar
good luck
Thanks, I'm headed to Home Depot right now to pick up one of those extracters.
post #4 of 7 Old 12-27-2005, 07:43 PM
Ruthless Racing's Avatar
Images: 9
good luck
Those extracters work great!!
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #5 of 7 Old 12-27-2005, 08:44 PM
PostWhore
GuitarPlyr's Avatar
Send a message via Yahoo to GuitarPlyr
yeah, the extractors work good sometimes, if you can get them to bite.....if not, you can drill a small hole in the head of the stripped screw to give the extractor something to grip...good luck
John 8:24:
Therefore I said to you that you will die in your sins; for if you do not believe that I am He, you will die in your sins."
GuitarPlyr is offline
post #6 of 7 Old 12-27-2005, 10:44 PM
Supercharged Mod
Another choice, if you know the thread size (measure the one you got out), is to carefully drill into the screw head using a drill bit that is the same size as the threads. The stripped screw head will act as a guide to center the drill bit, and beyond that, you will just have to be careful to drill absolutely straight down. Frequently take the drill out of the hole to check if you have made it through the head. It helps to make a little notch and knock it in a direction trying to turn the screw loose using a punch.
I've had to do that a couple of times. It's always a bit scary. Worst one was drilling out a stripped-out bolt that was holding the front pulley onto a car engine; had to be removed in order to replace the timing belt ...
GoFaster is offline
post #7 of 7 Old 12-27-2005, 10:47 PM
Supercharged Mod
By the way, I prefer drilling the head off instead of using extractors. The reason is that if you ever break one of those extractors off inside the screw, now you are *really* in trouble. You can't drill out the extractor, it's harder than any tool in the known universe - and they are very brittle.
GoFaster is offline
Head Gasket?????? SP8 Performance and Tech 13 10-26-2005 10:35 PM
Star Racing head updated (Dyno) rotts4u Performance and Tech 11 10-26-2005 06:32 AM
Star Racing head work on ZX-10 rotts4u Performance and Tech 39 09-21-2005 12:33 PM
Port & polish the head? 1killer1liter Performance and Tech 15 04-09-2005 11:00 PM
Gasket and Cam Install BNninja How To... 42 04-08-2005 09:55 AM
