Strange noise need help - Kawasaki ZX-10R.net
post #1 of 13 Old 03-26-2006, 10:10 PM Thread Starter
hangman39's Avatar
was riding today stopped at store after I started it back up had a rattle coming from the front left side of the motor the sound is almost like the sound of a leaf or something in a fan can not pinpoint the exact location will be taking fairings off next weekend to try and find it any ideas
hangman39 is offline
post #2 of 13 Old 03-26-2006, 10:23 PM
Might be a leaf in your can
ZXGREENMACHINE is offline
post #3 of 13 Old 03-27-2006, 06:11 AM Thread Starter
hangman39's Avatar
Thanks alot
post #4 of 13 Old 03-27-2006, 06:38 AM
Post Whore
Sgtusmc96's Avatar
LOL
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #5 of 13 Old 03-27-2006, 07:09 AM
front left area IS the cooling fan... so something could easily be in there
uzipoo is offline
post #6 of 13 Old 03-27-2006, 07:26 AM Thread Starter
hangman39's Avatar
That is what I thought because the fan was running at the time I first heard the noise but let it cool down and the noise is still there sounds more like it is coming from under the tank on the upper left side of motor
post #7 of 13 Old 03-27-2006, 07:50 AM
fastbikesrule's Avatar
Send a message via AIM to fastbikesrule
Exhaust leak???
fastbikesrule is offline
post #8 of 13 Old 03-27-2006, 08:24 AM Thread Starter
hangman39's Avatar
That was my first thought heard on here that they will get loose will be checking that first as soon as I get time to take fairings off
post #9 of 13 Old 03-27-2006, 08:12 PM
check to see if your radiator fell off it's top mount ! It happens i believe there is a thread on it .If i remeber correcly they drilled a hole throught the mount and put a cotter pin in it to keep it from slipping off. Hope this helps!
tbass is offline
post #10 of 13 Old 03-27-2006, 10:06 PM
Maybe let the bike heat up, watch the fan come on and see whats happenin? might spot the cause.
BigBlue is offline
51-54mph rubbing noise ? LittleNose Performance and Tech 8 03-08-2006 03:56 PM
hey i have a noise...... zfactor2004 The ZX-10R 18 11-07-2005 11:05 AM
Clutch making noise when engaged. JIKSER Performance and Tech 1 10-14-2005 10:07 AM
Leaving for Myrtle = Tickets durring Harley Week Vonstallin The ZX-10R 5 05-29-2005 11:02 PM
what the heck is that noise? MikeP The ZX-10R 28 07-05-2004 05:38 AM
