Strange howling sound!!!!!!! - Kawasaki ZX-10R.net
post #1 of 7 Old 07-05-2012, 10:44 PM Thread Starter
Darmentle's Avatar
my 07 has 2800 miles on it. And on Monday i changed out the front sprocket went down one in the front. And kept the stock rear sprocket and chain on because they are still in good condition. now i notice when i am cruising down the freeway in 6th gear around 75mph and let off the throttle and just let the bike decell on its own no brakes i am hearing this faint howling sound. Kind of like the sound a lifted truck makes with mud tires but really quite. Never heard the sound until i put the front sprocket on.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 7 Old 07-05-2012, 10:50 PM
Teeks's Avatar
Everything seated properly and tight? Did you torque the sprocket nut on, and bend the locking washer back into place. Might be worth a double check. Only other thing I can think of is that it would be noisy if you got the wrong pitch front sprocket.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 7 Old 07-05-2012, 11:02 PM Thread Starter
Darmentle's Avatar
Yeah i went to cycle gear and got it vortex front sprocket. tomorrow put it up on the stand and recheck. Yes the flat washer is bent back in to place.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #4 of 7 Old 07-06-2012, 10:46 AM
diesel10R's Avatar
i got the same noise on mine when i changed out the sprockets....check out the factory front....should have a rubber type shoulder for the chain to ride on.....aftermarkets do not....which from what i was told...makes this noise...my friends gsxr...same thing when sprockets were changed
ride or die!::weed :
diesel10R is offline
post #5 of 7 Old 07-06-2012, 12:06 PM
The rubber damper makes the sprocket run quieter.
trebor27 is offline
post #6 of 7 Old 07-06-2012, 07:59 PM Thread Starter
Darmentle's Avatar
Ok so its fine then cool thanks.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #7 of 7 Old 07-06-2012, 08:05 PM
flthy1's Avatar
+1 on what these guys said, also make sure your chain isn't too tight or loose
flthy1 is offline
howling sounds from my zx10 kawiboytwo The ZX-10R 7 07-19-2010 08:35 AM
my 04 10 has a howling noise kawiboytwo The ZX-10R 3 08-24-2009 10:36 PM
strange sound then trying to start.. fuel pump gone? video inside davitos The ZX-10R 11 02-24-2009 11:21 PM
my engine is howling!!! hollywood99 Performance and Tech 11 07-05-2008 06:23 PM
What's howling? CowTownZX-10R Performance and Tech 18 08-16-2004 10:27 AM
