Strange FI readings - Kawasaki ZX-10R.net
post #1 of 4 Old 04-12-2012, 03:49 PM Thread Starter
leemille's Avatar
Strange FI readings
hi i have a gen 1 zx10R engine in my race car. at the end last season i put the car on jack stands, drained the water and attached the battery minder.
this month i put the water back and turned on the power, oopps a FI light is on. the reading of the error code produces 1 1 1 1 4. anybody have a guess what that sequence is trying to tell me? i thought that all error codes were two digits.
i have a GIPRO, a power commander USB and a flat shifter. the sub-throttle butterflys are gone.
leemille is offline
post #2 of 4 Old 04-13-2012, 07:12 PM
badassjake's Avatar
That's a 44 code......i think....the manual covers the signals, download one for free. Worth ever penny
badassjake is offline
post #3 of 4 Old 04-13-2012, 07:32 PM Thread Starter
leemille's Avatar
strange FI light
thanks, i thought of that. so far i have checked error codes 11 and 14 and found no problem. tomorrow i will switch the connectors for injector 4 and 3 and see if the code changes. i have the manual.
leemille is offline
post #4 of 4 Old 04-14-2012, 03:43 PM Thread Starter
leemille's Avatar
solved
four individual long blinks and 4 fast blinks turns out to be 44. there was a loose connector on injector 4.
i would have expected 4 short blinks followed by 4 more short blinks.
thanks for the help.
leemille is offline
Gen 1: TPS readings zuhayr Performance and Tech 5 10-05-2011 01:15 PM
Erratic Speedo Readings pls Help Larry Grogan Performance and Tech 13 08-15-2010 09:25 PM
Bikes ECU defaults to Dyno Mode for higher Horsepower readings? MagicMavis General Motorcycle Discussions 71 04-26-2010 12:01 PM
Voltage Readings coach Performance and Tech 0 02-23-2006 01:34 PM
Strange in here lately. legz10r The ZX-10R 33 09-25-2005 01:00 PM
