Gen 4: 2011-2015 Strange error codes with kit ECU - Kawasaki ZX-10R.net
post #1 of 2 Old 05-19-2019, 02:00 PM Thread Starter
Hi
I have installed a kit ECU and harness on a zx-10r 2013. There seem to be a few problems:
1) I am getting error codes 1b - 3C, which I understand is ABS and steering damper. This seems strange because the ABS is removed and the race ECU certainly does not support this. This is the same with the steering damper (which is now manual).
2) The ABS Indicator Light and the Warning Indicator Light (Yellow) (just beside) are both on when driving.
3) The Warning Indicator Light (Red) blinks when the ignition is off.
4) I am not able to adjust the shift light, by pressing upper and lower buttons while blinking etc. according to the user manual. It went up to 14000 but does not restart on 9500 as it should, when holding the second button down.
I would be grateful if anyone could shed a light on any of these issues. Thanks!
Regards,
Aksel
aksels is offline
post #2 of 2 Old 05-20-2019, 12:26 PM
From previous experience (with my Gen 5) all units must be plugged in, switched to off with the kit stuff then can be removed.
On mine I removed the SD and then turned it off but couldn’t get the CEL off till it was plugged back in.
theducatiman is offline
How do you retrieve/ read error codes. Having motor issues... cowasaki The ZX-10R 7 06-21-2010 12:50 PM
DFI error codes. 880turbo Performance and Tech 1 02-06-2010 09:28 AM
Retrieving PREVIOUS error codes? lenshead Performance and Tech 3 03-18-2009 11:39 PM
stange FI error codes leemille Performance and Tech 1 11-21-2006 03:13 PM
How to pull error codes on 06'??? deezuhl Performance and Tech 8 08-27-2006 02:53 PM
