stock velocity stacks - Kawasaki ZX-10R.net
post #1 of 14 Old 04-04-2013, 09:30 PM Thread Starter
has anyone swapped the long and short ones around to see if there is any gain ? I was wondering if swapping the long ones to where the short ones are does anything or do they run best as is ? Steve
felix1 is offline
post #2 of 14 Old 04-04-2013, 09:34 PM
Supercharged Mod
Lots of people have tried putting short ones on the middle two cylinders, but at least on the earlier models, you cannot put the long ones on the outside; won't clear the walls of the airbox ...
GoFaster is offline
post #3 of 14 Old 04-05-2013, 08:03 AM
zx racer's Avatar
i did this mod and its good for more topend power but you loose lil bit on the lowend.
05 ZX-10R SWB.
zx racer is offline
post #4 of 14 Old 04-05-2013, 09:07 PM Thread Starter
I have a 04/05 engine in a dwarf car and there is a company that makes an air cleaner assembly that uses stock velocity stacks so I can run them any way I want, I can go all short or all long or mix them up, going to hit the dyno soon for a tune and maybe we will have time to play with some different options, Steve
felix1 is offline
post #5 of 14 Old 04-06-2013, 01:54 AM
thundercoupe9's Avatar
I wouldn't mess with them unless you can control fuel/ignition trim in each cylinder. Inside 2 cylinders have different map than the outside 2 cylinders. Outside cylinders make little more power on the top end and the inside ones more power in the lower rpms. If you put all short or all long stacks on every cylinder without changing the maps inside the ecu, outside or inside cylinders will always be too lean or too rich at certain rpms.
thundercoupe9 is offline
post #6 of 14 Old 04-06-2013, 02:57 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
I've tried running all 4 stock shorties and seemed to have lost a little lower and midrange but i ended up getting lucky on ebay and found a seller who had an airbox/stacks/and filter for sale CHEAP but he had these in there! i've ran them every since and love em'!!! i adjusted the custom map in my PC and she pulls good from down low on up. one of those mods that don't make a huge difference by itself, but added with a couple others it seems to make a difference imo anyway. and as said above, on the gen 1 you can't run all 4 tall stacks anyway so you're only real option is 4 shorts or these.
ID:	188434   Click image for larger version
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #7 of 14 Old 04-08-2013, 12:24 AM Thread Starter
very nice, and probably expensive too
felix1 is offline
post #8 of 14 Old 04-08-2013, 11:40 AM
gazx10's Avatar
i was tuned on stk. stacks, switched 2 more short, killed my powerband, even up top. 07 we have tuned all short, runs great.
gazx10 is offline
post #9 of 14 Old 04-28-2013, 06:12 PM
back to car scene
ls1leadfoot's Avatar
im taking them out of my bike, im wondering if it will be a noticeable diff
ls1leadfoot is offline
post #10 of 14 Old 04-28-2013, 08:28 PM
If I'm running nitrous spray bar would it be a bad idea switching to all short on my 07 then getting a tune? Looking for more power
Boostedgreddy is offline
velocity stacks ZxTennessee Performance and Tech 32 11-18-2010 06:26 AM
Velocity Stacks 04-05 garth285 Parts, Gear and Accessories 8 03-27-2010 02:05 AM
Velocity Stacks? Scavenger8620 The ZX-10R 11 12-15-2008 11:38 AM
Velocity Stacks! AGENTORANGE636 Wanted: Buy or Trade 3 10-10-2006 09:45 PM
Velocity Stacks fast1 Performance and Tech 12 01-20-2005 09:01 AM
