stock stacks - Kawasaki ZX-10R.net
post #1 of 6 Old 10-18-2007, 09:06 AM Thread Starter
stock stacks
What would happen if I removed the stock stacks in the airbox? Any gain on low end etc...????? Does this hurt anything at all???? Just wondering any info would help, or should I just buy a pair of new velocity stacks.
howitzer is offline
post #2 of 6 Old 10-18-2007, 10:05 AM
FAF
Rent this space
If you removed them , you would lose more low end.
FAF is offline
post #3 of 6 Old 10-18-2007, 11:13 AM Thread Starter
just low end? would i gain in top and midrange though??
howitzer is offline
post #4 of 6 Old 10-18-2007, 02:05 PM
FAF
Rent this space
Nope, they are a tuned length for the engine, the aftermarket ones dont do much either , maybe a hp or two up top.
FAF is offline
post #5 of 6 Old 10-18-2007, 02:12 PM
Speed Freak
garth285's Avatar
yeah the factory pro ones should really be used with degreed cams other than that Im not sure they are worth it... you can go the extra mile like me and get a tuning kit from factory pro which is all the rubber boots but a bunch of different length stacks and dyno tune your motor to what makes best power where you want it... I wound up going with the factory pro shorties and I think 35mm centers....
you pretty much will be loosing power everywhere if you remove the velocity stacks I think....
garth285 is offline
post #6 of 6 Old 10-19-2007, 08:35 PM
sextaafondo's Avatar
I phoned FactoryPro to ask for an extra pair of shorties for cyl.2 and 3, and the guy said that I would pretty much loose power everywhere with that configuration. As his opinion is, it would be worth it to install a pair of 35mm at cyl.1 and 4, but there´s no room for that. His words. I don´t know from my experience.
sextaafondo is offline
Anybody Try 4 Short Stacks? inginekilla Performance and Tech 15 07-06-2007 05:35 PM
Stacks appocalypse Vendor Deals 5 05-23-2006 02:31 PM
velocity stacks ninja2k5 Wanted: Buy or Trade 2 05-17-2006 10:31 PM
PC III and stacks question lavudyar Performance and Tech 5 01-02-2006 07:32 PM
