stock master cylinder ? (front brake) - Kawasaki ZX-10R.net
post #1 of 8 Old 12-14-2005, 01:58 PM Thread Starter
Ok Guys
Got a quick question in regard to the stock master cylinder on the front brake of my 05 zx-10r.
I have fitted brake lines..bleed them..my brakes feel strong..but whats bugging me is the slack in the lever travel,before it seems to move the piston in!....1/system has been bleed feels nice and firm..2/I've cracked the banjo by the master cylinder to bleed any air that may have gotten trapped there and bleed the whole system twice.....it seems to be a problem with the piston moving to much....just wondering if anyone has gotten the stock system to work good for themselves...I know lots of people just junk the stock master cylinder and replace it with something else..Just want to see if I can try and make the stock one work for me....I'm quite happy with my brakes..just the travel (slack?) the stocker has.....Thanks Steve........
I also had a problem like this once with a 01 gxsr600 I owned and ended up placeing a thick washer on the end of the piston!...it worked....and the zx10r master cylinder looks almost the same as the suzuki...
speedkelly is offline
post #2 of 8 Old 12-14-2005, 02:05 PM
Big Daddy's Avatar
Images: 38
Many have done exactly what you have, i.e. ss-lines, quality fluid, aftermarket pads and still the lever travel is no better, so baring replacement of the OEM MC i'd say thats it. If your inclined to try the washer/spacer coonass Mod then be my guest and let us know the results.
moved to tech
Big Daddy is offline
post #3 of 8 Old 12-14-2005, 02:26 PM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
moved to tech
As BD said and from my own experience with it it really does not get any better with line,pad, and fluid upgrades. Personally I have a Brembo 19x18 mc that is amazing and the answer to all my braking problems and brake fade. I believe some here have gone with the 05 zx-6r's mc with pretty good results so do a search and you should find some good info.
zx10ragentblack is offline
post #4 of 8 Old 12-14-2005, 03:13 PM Thread Starter
Spacers!!!
Thanks for quick reply big D.....yep I guess I'm got some coonass in me..cause I'm forever using washers for stuff...shimming carb needles...rear shocks and such... hell I even made pre-load fork spacers for my 1st race bike (honda hawk 650) out of plastic plumbers pipe...in fact once back in the old uk it was cheaper to use to 2 pence coins to pre-poad the fork springs on my yamaha RD350...guess I'm giving my age away little here.....but I will let you know how it work,s...
Ok so my next question is which M/Cs fit the zx10r...I was looking @ the new 04/05 R1 and the m/c looks good to me ...better start trolling ebay huh..
So basically no one seems to be able to get the stock M/C to work ??...steve...(the coonass british guy)
post #5 of 8 Old 12-14-2005, 03:21 PM
Yankee Racer
Images: 9
post #6 of 8 Old 12-14-2005, 04:24 PM Thread Starter
M/Cs
Ok...Looks to me like any radial M/Cs from the a newer 636 or yamaha R1 or R6 (04/05) and all gsxr's (04/05) should me able too made to work with the zx10r.....any one used a M/C from anything other than a 636?...if not I will let you guy's know in a few weeks how I get along...Steve...
post #7 of 8 Old 12-16-2005, 05:39 PM Thread Starter
ok "told you so!"
ok the washer..."cheap bodge" did not work...even with the thinest washer I had..the piston was some how not fully returning and pressure would build up in the system and would eventually cause the brakes to drag....back to the drawing board on that one then.
I think I will try a radial master cylinder from another 05 bike....like the look of the suzuki and the yamaha..seems to be a whole lot cheaper then going the 636 route....although the unit will be black not that nice golden green color..(i can live with that tho)..will let you guys know how I get on once I purchase one off ebay and get it installed.....so far the only problems I may have to twist round the throttle cables a little and one end of my brake line will have too have the fitting changed...but I live next door to earls (brake line shop) so should not be a problem...steve
post #8 of 8 Old 12-16-2005, 05:44 PM
Big Daddy's Avatar
Images: 38
aight dammit quit postin and git er dun!!
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Yamaha R1 05 front master cylinder?? rvfbill Performance and Tech 4 10-24-2005 09:09 AM
Front brake master cylinder question ninja9r The ZX-10R 0 03-25-2005 11:13 AM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
Brembo Master Brake Cylinder choice realestateguy The ZX-10R 11 12-10-2004 06:59 AM
