stock intake cam for exhaust - Kawasaki ZX-10R.net
post #1 of 10 Old 08-17-2007, 09:13 PM Thread Starter
jimbob8915's Avatar
I know for hayabusa's a very popular mod is to get a performance web or megacycle intake cam and put the stock intake cam in place of the exhaust cam. Does anyone know if it is possible to put the kawasaki race cam in and use the stock intake in place of the exahust? Or maybe a cam from anouther year or model. I know gixxer cams are swappable from different years and models.
06 ZX10R Ported 04 Head, .55mm head gasket, 08 Race Intake cam, stock intake pinned and moved to exhaust, 107/107, PCV, with Auto tune. 178 rwhp through Boz Bro single side high mount exhaust.
jimbob8915 is offline
post #2 of 10 Old 08-17-2007, 10:19 PM
Speed Freak
garth285's Avatar
I have done it, you can do it as well but its kinda tricky and you need the right tools to modify the stock one, the metal is extremely hard, I broke 2 taps doing so..... its possible but with a stock motor there isn't much to be gained unless fine tuned.... I don't have access to the dyno sheets that i have done with that testing but it didn't yield me any more hp with stock pistons down. Now that I have a built motor and larger displacement I might modify a stock one i have layin around again.
garth285 is offline
post #3 of 10 Old 08-22-2007, 06:04 PM
10rmotor's Avatar
Garth, how did you deal with the cam sensor lobe that is present on the exhaust cam not being on the intake cam?
10rmotor is offline
post #4 of 10 Old 08-22-2007, 06:39 PM
Speed Freak
garth285's Avatar
Thats where the time and money factor comes in lol...... I used a I think 4mm bolt and drilled and tapped the camshaft. I basically got the position of the sensor.... drilled it in the same spot on the intake side.... tapped it.... and ran the bolt threw it.... then I measured the height of the cam position lobe and ground down the bolt to copy the lobe on the exhaust cam..... I was running it on my bike for a while and when i tore my motor down I sold it and I was going to make a new one.... never had the time so threw in the stock exhaust but I Want to do it again I just dont have the tools now so it will have to wait.
garth285 is offline
post #5 of 10 Old 08-22-2007, 08:18 PM
cow10r's Avatar
Yep. It works
cow10r is offline
post #6 of 10 Old 08-22-2007, 08:19 PM
Speed Freak
garth285's Avatar
was it you I sold the cam to?
garth285 is offline
post #7 of 10 Old 08-22-2007, 08:45 PM
10rmotor's Avatar
Backwoods engineering at its best. I love it.
Originally Posted by cow10r View Post
Yep. It works
Does that mean its an improvement over the stock exhaust cam?
10rmotor is offline
post #8 of 10 Old 08-22-2007, 08:46 PM
Speed Freak
garth285's Avatar
I think on a stock motor it wont show much gain but on a modified it will. Theres not much performance to be gained on the exhaust side of the cams.
garth285 is offline
post #9 of 10 Old 08-22-2007, 09:44 PM
cow10r's Avatar
nope
cow10r is offline
post #10 of 10 Old 08-22-2007, 09:50 PM
cow10r's Avatar
I didnt do a before and after, but it works on a lot of other bikes. It sure didnt hurt and its free.
cow10r is offline
Intake & exhaust cam specs 11outa10 Performance and Tech 11 12-05-2007 06:40 AM
zx10 ITEMS ON EBAY. STOCK EXHAUST, STOCK SIGNAL, QUARTER TURN THROTTLE. ENDING 2/13 Eric_The_Jew Parts, Gear and Accessories 0 02-12-2007 12:35 PM
Intake Cams Back in stock Mad_man Performance and Tech 4 09-07-2006 06:14 PM
stock intake cam and stock windscreen ninja2k5 Parts, Gear and Accessories 1 05-23-2006 09:01 AM
Thin head gasket, bigger intake and exhaust cams, 1killer1liter The Out House 12 04-28-2006 06:12 PM
