Stock exhaust removal question - Kawasaki ZX-10R.net
post #1 of 16 Old 08-02-2007, 04:26 PM Thread Starter
dbltakeZX10's Avatar
Images: 22
Send a message via AIM to dbltakeZX10 Send a message via Yahoo to dbltakeZX10
I am having trouble removing my stock exhaust. I couldnt get the swing arm heatshield off the bike cuz the screws got stripped. Is that any other way to get the pipe out. Its the bottom weird looking pipe. Thanks in advance.
dbltakeZX10 is offline
post #2 of 16 Old 08-02-2007, 04:29 PM
Are you talking about the cat and headers, becuase it looks to me that you have the other pipe out that might be alittle difficult without takin that heat sheild off.
BryanB is offline
post #3 of 16 Old 08-02-2007, 04:35 PM
Retired post whore
Alien10's Avatar
I think a couple of 06-07 owners on the forum had this same problem with the 3 screws on the heatshield strippin out.
Alien10 is offline
post #4 of 16 Old 08-02-2007, 04:38 PM Thread Starter
Images: 22
Yep its the black shield with 3 bolts. That pic is just a pic of what I'm talkin bout. What did u guys do when this happens??
post #5 of 16 Old 08-02-2007, 05:34 PM
i personally didnt have that probelm. So just so i know whats goin on and not getting things mixed up. You have that one pipe stuck behind that heat sheild and you cant get the pipe out. Correct?
BryanB is offline
post #6 of 16 Old 08-02-2007, 05:39 PM Thread Starter
Images: 22
exhaust
correct. that y shape pipe is stuck between the bike where the swing are is. there is a black shield that comes out with 3 bolts but the screws are really soft, and strip easy. ill see if i can find a pic of it. you can see one screw in the pic. the one u can see is the one that is by the swing arm
post #7 of 16 Old 08-02-2007, 05:52 PM
yea, thats a fun job, lol. the only thing i can say to do because i dont have a 10 infront of me anymore is to gently lay the bike down in the grass and loosen the pipe from the cat and see about loosing the cat from the header. I wouldnt recommed removing the header unless your replaceing the header(such as putting a new full system on. Also from the looks of it you will be trying to pull it up from the top(when the bike is standing, but leave in layin on the ground). Dont think it will come out from the bottem. When i took mine off it twisted right out from the hole(when you remove that black heat sheild and rearset. Try that and let me know. i'll go see if i cant talk to someone for you.
BryanB is offline
post #8 of 16 Old 08-02-2007, 06:08 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
GOOD LUCK that things a bitch to get off the screws have Yellow lock tite on them I got one out stripped the other 2 then i broke one off in the swingarm with an ez-out so after that i still have one screw to go so me and the boys broke the plate off and removed the last screw w/visgrips.Luckily for me my man had another plate and screws for me for $20. Like I said Good Luck a 1 hour job was 4 because of that dam plate.
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
post #9 of 16 Old 08-03-2007, 07:21 AM
Use a centre punch and give a sharp tap in the centre of the screw to break the loctite. If the allen part is too chewed up to get a grip, then get a cold chisel, sharp, and strike it at 90 degrees to the screw, to get a depression to work with. Then, lean the chisel to about 45 degrees and tap the screw anti-clockwise using the top or bottom of initial cut to unscrew it, I found after about half a turn I was able to get a flat screwdriver into the cut and unscrew it manually. I tend to tap into meat of the swingarm, so as not to break off, or deform the metal tab.
Hope that makes sense, it's easier than it sounds. I had the same problem on my 2007 10 and this solved it.
doug_uk is offline
post #10 of 16 Old 08-03-2007, 09:04 AM Thread Starter
Images: 22
exhasut
Is it safe to lay the bike down with all the fluids in it? Do i need to drain anything? How long can you lay it down for? I think it will come out of the top if you give it more room by seperating the subframe and rear tire almost like your raising the bike. Thanks for all the help guys.
Stock exhaust question Bigcat#44 The ZX-10R 8 02-13-2007 10:34 PM
2006 Stock Exhaust Valve Question modpup The ZX-10R 5 08-13-2006 02:34 AM
Stock Ohlins removal dangerous22 Performance and Tech 8 07-10-2006 05:14 PM
Exhaust Servo Motor Removal Question Larry Grogan The ZX-10R 1 02-27-2006 10:04 PM
stock muffler cat/baffle removal ktgraf Performance and Tech 13 09-25-2005 10:54 AM
