Sticky throttle on '04 10 - Kawasaki ZX-10R.net
post #1 of 5 Old 04-20-2008, 12:09 AM Thread Starter
ericande's Avatar
I have an '04 to and the last few hundred miles I've noticed the throttle is starting to get sticky. If I'm cruising at 80 or so and let go of the throttle the RPMs just slowly drop, if I rotate the grip forward it slows quickly like you'd expect. In the garage if I open the throttle it doesn't snap back quickly. Question is: is it likely the throttle cable itself or the springs in the return (if that's how it works.) Where do I start looking? Sorry if this has been answered, I searched for a few minutes and couldn't find anything.
ericande is offline
post #2 of 5 Old 04-20-2008, 12:17 AM
ducatiryder89's Avatar
Images: 21
Try using some cable lube. Also check your grips to see if it rubbing along the throttle housing.
ducatiryder89 is offline
post #3 of 5 Old 04-20-2008, 12:48 AM
Judge Dredd Mod
mr_honez's Avatar
Lube your cables. No.1 cause of sticky throttles. Cable lubers are cheap, and its easy to do.
BURNOUT.....
mr_honez is offline
post #4 of 5 Old 04-20-2008, 07:43 PM
Vince10R's Avatar
Also check to mke sure the grip hasnt moved and its not rubbing on the cases that hold the cables.
Vince10R is offline
post #5 of 5 Old 04-20-2008, 07:58 PM Thread Starter
ericande's Avatar
Thanks, I'll check the grips and then lube the cables when I get the bike back from the shop. I'm guessing lubing the cables will help because the bike has 20k on it.
ericande is offline
Beware, heated grips + thin throttle tube = stuck throttle Drain Fade The ZX-10R 3 10-14-2007 02:34 PM
06 PDF Sticky MY oo ITCH ZX-10r.net Site Help, Suggestions and Questions 6 12-06-2006 08:28 AM
Sticky Louks03 Performance and Tech 6 05-10-2005 07:56 AM
