Sticking Throttle Cured ! - Kawasaki ZX-10R.net
post #1 of 4 Old 02-02-2008, 04:24 PM Thread Starter
abadassbikerlad's Avatar
Send a message via MSN to abadassbikerlad
hi been putting up with rather dangerous sticking throttle i could not get the bike to tick over less than 1800 rpm and if i revved it above 10 grand it would hang at about 8500 for ages.
i tried the usual oiling cable with cable oiler no luck, i rang kawasaki uk and 2 boffins could not give me any idea what it would be.
So i took of the throttle bodies and found a seized little arm that opens throttle with the secondries it had stuck corroded in our winter from the salt on the roads.
it has a c clip and little plastic washer under it, it was so solid it would not turn more than about 3* so i squirted some lube on it and used some little grips to wiggle it free, i could not quiet get it off its shaft but its free and moves nice now, If you ride your bike in bad weather i would expect to look here for any throttle sticking problems.
abadassbikerlad is offline
post #2 of 4 Old 02-02-2008, 05:18 PM
thrill's Avatar
thanks for the tip. I ride all weather
thrill is offline
post #3 of 4 Old 05-01-2008, 10:30 PM
Thanks for the info. My bike just started doing the same thing!! I will have to look for this to see if that is it. do you happen to have pics?? if not would you mind giving general directions? If it is something complex that i shouldn't mess with, then i will have it done at the shop, but i would like to be able to do it myself. Thanks again for the post and i would appriciate any info....
ZX10R_Yell06 is offline
post #4 of 4 Old 10-01-2012, 07:53 PM Thread Starter
Sorry for replying so late it's the fast idle adjuster on the left hand side of the throttle bodies your see it move when you open throttle full then return it hard to its stop.
My throttle grip is sticking TI10 The ZX-10R 14 08-01-2007 12:41 PM
under 25mph SQUEAK CURED abadassbikerlad The ZX-10R 2 06-09-2007 07:02 PM
Sticking decals YZF Performance and Tech 2 08-24-2006 11:35 AM
Throttle sticking, any ideas? SiP Racing09 Performance and Tech 12 03-22-2006 12:23 PM
Anyone had a Problem with their Throttle Sticking garageworks The ZX-10R 17 09-13-2005 04:09 PM
