Gen 4: 2011-2015 Steering damper - Kawasaki ZX-10R.net
post #1 of 17 Old 06-29-2014, 07:59 PM Thread Starter
Tech5's Avatar
Steering damper
12-14 what are using ????
Tech5 is offline
post #2 of 17 Old 06-29-2014, 09:01 PM
SDsting's Avatar
Images: 22
stock. wouldn't change unless I dedicated my bike to the track only
Yoshimura ... DynoJet PCV ... ECUleashed flash ... BMC race airfilter ... DynoTuned ... K-Tech 20DDS Fork/Cartridges ... K-Tech 35DDS Rear Shock ... Rear Linkage kit ... Brembo T-Drive rotors ... Accossato Master Cylinder ... Vesrah pads ...
SDsting is offline
post #3 of 17 Old 06-30-2014, 06:00 AM Thread Starter
Tech5's Avatar
Stock shocks on street !!!
I get tank slaps all the time
But I also ride hard as he'll too
Tech5 is offline
post #4 of 17 Old 06-30-2014, 06:21 AM
SkyDork's Avatar
Get your suspension tuned better. If you were getting "tank slaps all the time" you would've dumped the bike by now. A little wiggle is normal and the stock damper is more than adequate.
Ohlins sells a race SCU for the electric damper for racing and kyleusa.com can revalve the manual one. Been covered in-depth before.
#WordCrimes
SkyDork is offline
post #5 of 17 Old 06-30-2014, 09:59 AM
SDsting's Avatar
Images: 22
Originally Posted by SkyDork View Post
Get your suspension tuned better. Sent from Motorcycle.com Free App
after 20hp was added to my bike I was getting headshake as the front end was getting real light in all the gears under hard acceleration. I thought it was a steering damper issue, discussed it at the time with SkyDork and he pointed out that replacing the damper with a stiffer one at this point would be masking the problem, real issue is with the chassis setup. So I discussed it with my shop and they agreed, said what I really needed to take care of this was to replace the rear linkage. Wound up doing that + a full suspension replacement at the same time, but the headshake issue was gone. Oh and another good tip SkyDork gave was not to hold on to the bars too tight, donít man-handle it too much.
SDsting is offline
post #6 of 17 Old 06-30-2014, 10:19 AM Thread Starter
Tech5's Avatar
I was thinking this was the issue too, thank you guys so much for the information.
What linkage did you go with? ???
again thank you for this information , my problem happen right after making more power
Tech5 is offline
post #7 of 17 Old 06-30-2014, 10:35 AM
vr6
Get a new rear spring, get the shock re-valved for your weight (if you weigh more than 175lbs without gear.) Send damper to Kyle racing for revalve.
And have your suspension set up by someone who knows what they are doing.
Before I did all this I could not got wot. Now my bike has the smoothness of a 600 under wot; it's really an amazing transformation!!!
vr6 is offline
post #8 of 17 Old 06-30-2014, 10:55 AM Thread Starter
Tech5's Avatar
I LOVE IT!!!!
THANK YOU SIR
Tech5 is offline
post #9 of 17 Old 06-30-2014, 11:07 AM
SDsting's Avatar
Images: 22
Lee's Cycle rear linkage, developed by Jeremy Toye
SDsting is offline
post #10 of 17 Old 06-30-2014, 12:35 PM
vr6
I LOVE IT!!!!
THANK YOU SIR
You're welcome
vr6 is offline
Gen 1 GPR V4 Steering Damper and a HyperPro RSC Steering Damper prboarder Parts, Gear and Accessories 6 09-24-2011 03:11 PM
Gen 1: Need steering damper mount for a toby damper Ftw7626 Wanted: Buy or Trade 6 09-03-2011 08:23 PM
Steering Damper oxthegrunt Wanted: Buy or Trade 5 08-24-2010 03:24 PM
04/05 ZX-10R Steering Damper kit made from gsxr damper syntheticreality Parts, Gear and Accessories 0 05-03-2010 10:20 AM
04 636 Scotts steering damper MOUNT kit only (No Damper) grt shape JT10R Parts, Gear and Accessories 0 06-24-2008 09:40 AM
