STD verses SEA DYNO NUMBERS - Kawasaki ZX-10R.net
post #1 of 3 Old 05-14-2011, 01:55 PM Thread Starter
Why do some dyno operators use SAE and some use STD numbers on the dyno,and what is the percentage difference?I know STD read higher
speeddemon is offline
post #2 of 3 Old 05-14-2011, 04:12 PM
gazx10's Avatar
SAE and STD horsepower numbers are both set by the society of automotive engineers, and both are corrected to slightly different temperature and barometric pressures. SAE is calculated at 77 degrees and about 29.2 inches of mercury, STD is calculated at 60 degrees and almost 30 inches of mercury. the correction factor differs 17 degrees and .7 inches barometric, the hp readings are approx. 4% higher for the STD reading due to cooler more dense air factored over the SAE measurement. barometric pressure is largest factor, not temp. in our real riding world, you can run pretty close to normal on a hot day, but let the barometric pressure drop or climb in elevation, both result in less dense air, and you will lose hp. for our tens, the hp diff. is generally 6-7 hp lower SAE vrs. STD #.
gazx10 is offline
post #3 of 3 Old 05-14-2011, 08:21 PM Thread Starter
Thanks that was what i was looking for.
O.K.the dyno numbers are in.. aussie10r The ZX-10R 18 08-21-2009 01:27 AM
2nd Gen Dyno Numbers OneSLOW10 Performance and Tech 19 06-05-2008 11:12 PM
Dyno numbers zxfreak The ZX-10R 52 05-11-2008 02:04 PM
Dyno Numbers - Wow - mikebar4 Performance and Tech 103 01-04-2008 11:09 AM
Awesome first rally and dyno run share dyno numbers No-Mo The ZX-10R 36 05-19-2006 05:53 PM
