Gen 3: 2008-2010 stator voltage????? - Kawasaki ZX-10R.net
post #1 of 6 Old 06-16-2011, 06:51 AM Thread Starter
stator voltage?????
Does anyone know what voltage the stator should be at when sitting at idle at each wire?
Iamthatguy is offline
post #2 of 6 Old 06-16-2011, 06:58 AM Thread Starter
That would be at the plug into the regulator/rectifier.
post #3 of 6 Old 06-16-2011, 06:58 AM
kllrvet's Avatar
At about 4-5k it should be 50-60v AC
ZX14 cam chain tensioner making noise? I have the set it and forget it fix. PM me if I can help.
kllrvet is offline
post #4 of 6 Old 06-16-2011, 07:09 AM Thread Starter
I put the meter on 20v dc and only 1 wire was reading and it was a little over 12v.
post #5 of 6 Old 06-16-2011, 08:17 AM
kllrvet's Avatar
Gotta check ac from stator not dc. You test a pair of leads at the plug when disconnected from regulator. Total of three tests. Must be done at higher rpm not idle.
kllrvet is offline
post #6 of 6 Old 06-16-2011, 09:08 AM Thread Starter
Alright I will do that probably today when I get home. I did not know that. So it should be between 40-50ac at 4-5k rpm. Anything else I should know?
Voltage problem? Quantrill The ZX-10R 4 06-03-2011 02:06 AM
Battery voltage?? TexasRider Performance and Tech 1 01-17-2011 09:55 PM
tps voltage range ryd2nrz Performance and Tech 3 03-24-2010 05:27 PM
Fan Voltage ? Felix el gato Performance and Tech 2 08-20-2007 05:01 PM
Voltage Readings coach Performance and Tech 0 02-23-2006 12:34 PM
