Stator or Regulator - Kawasaki ZX-10R.net
post #1 of 22 Old 06-22-2010, 04:58 PM Thread Starter
JaydeeZX10's Avatar
Images: 7
Send a message via AIM to JaydeeZX10 Send a message via Yahoo to JaydeeZX10
Stator or Regulator
Fellas as of Yesterday my bike drains my battery while riding. I replaced my battery yesterday afternoon since it was the oem battery figuring this was the cause. Today she died again while riding. I did some searching and found how to test the Stator. It reports .01 ohms at each connection. However when i turn the bike on and rev the engine to 4k rpms the Battery reads the same voltage as before starting the bike not higher. Am I correcting in assuming that its the regulator thats bad?
2007 ZX10
JaydeeZX10 is offline
post #2 of 22 Old 06-22-2010, 05:05 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
It's either the stator or rectifier.....i'd put my money on the stator if it drains the battery while riding-running. had it happen a few times on some of my other bikes.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #3 of 22 Old 06-22-2010, 06:24 PM Thread Starter
JaydeeZX10's Avatar
Images: 7
Ok I'll start with replacing the Stator then. Thanks.
2007 ZX10
post #4 of 22 Old 06-22-2010, 06:53 PM
Kachek1990's Avatar
stator had the same problem
Kachek1990 is offline
post #5 of 22 Old 06-22-2010, 07:06 PM
dmj120's Avatar
If you have a good meter, ohm it out. The specs are .1-.2 ohms; mine was .3 and FRIED.
dmj120 is offline
post #6 of 22 Old 06-22-2010, 07:21 PM Thread Starter
JaydeeZX10's Avatar
Images: 7
Mine was at .01 which is strange cuz thats within normal range.
2007 ZX10
post #7 of 22 Old 06-23-2010, 07:58 AM
Yourmyboyblue3's Avatar
I would replace both of them, i know its allot of money? but it will help you down the road trust me I had to replace both. if you only replace one it is going to eat up the other one. From what I understand this is a common thing with the 10's might not happen to everyone but it happens to allot of us.
Why blend in, when you can stick out...
Bikes:
01 Yamaha R6 (SOLD)
03 Suzuki GSX-R 750 (SOLD)
07 Kawasaki ZX-10r WINNING!!!
07 Candy blue ZX-10R, Zero Gravity double bubble wind screen, K&N Air filter, 2 bros full system exhaust, PCIII with Custom map, starrotors 8000K HID kit, ASV C5 Gold shorty levers, Ohlins Damper, Puig rear tire hugger, Solo seat cowl, black painted foot pegs...
Yourmyboyblue3 is offline
post #8 of 22 Old 06-23-2010, 08:02 AM
TMAC's Avatar
Images: 86
I replaced both but mine was just the stator. You can also check the rectifier with a multi-meter per the service manual
2007 ZX-10R - 156 RWHP/182 MPH
2009 KX450F
2006 636 (Sold)
99 ZX-6R (Sold)
94 Ninja 250 (Sold)
99 YZ-250 (Sold)
73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htm
TMAC is offline
post #9 of 22 Old 06-23-2010, 09:50 AM Thread Starter
JaydeeZX10's Avatar
Images: 7
How did you guys get your hands under the bike to test it?
2007 ZX10
post #10 of 22 Old 06-23-2010, 10:02 AM
you should be able to reach it if you are on the right side of the bike (Looking at it from the back). you should see the cables that come from the stator to the reg.
Bikes:
01 Yamaha R6 (SOLD)
2007 zx10r - Stator or Regulator black&flames The ZX-10R 36 05-11-2015 01:25 PM
Replacement Regulator? Vee4me The ZX-10R 1 11-04-2009 11:35 AM
Wtd: '05 Regulator Rectifier RussMcB Wanted: Buy or Trade 5 04-03-2007 11:05 PM
regulator rectifier Rock_Star Performance and Tech 5 10-09-2006 06:56 PM
Volter Regulator? special k Performance and Tech 4 09-12-2006 08:20 AM
