Stator failure? - Kawasaki ZX-10R.net
post #1 of 13 Old 11-29-2014, 10:03 PM Thread Starter
Matteson's Avatar
Stator failure?
New battery. Started up fine and was sitting in the driveway gearing up and I heard a grinding from the motor and the bike died down. Gave it throttle and she died. Hit the starter button and the grinding again. Hit the starter again and it fired up. Went on a ride about 3 miles up the road and was turning around and it died on me. Nothing when I cranked it. Then got to a parking lot and got the "clicking" noise when I tried starting it. I got my car and hooked up the jumpers and it fired right up. Made it a block and it died on me. I checked the stator connections and there was no sign of corrosion. The regulator appears to be a pain in the ass to get too to check. But I looked up some stuff on the net and found some burned up stators and was wondering if this was a symptom?
Matteson is offline
post #2 of 13 Old 11-29-2014, 10:27 PM
slowmoves's Avatar
If you download the manual for you year model it will walk you through how to check all that, Its really simple. Also I'm not sure which gens were fully effected. But the Gen 3 have a warranty bulletin on the regulators, But when My stator went out my local kawi shop was able to get kawi to replace the stator with the regulator since it caused the stator to die. Mine died on me in a parking lot, I have a shorai battery and it didn't show any signs of getting weak, just died! But download the manual and get to checking!
slowmoves is offline
post #3 of 13 Old 11-29-2014, 10:35 PM Thread Starter
Matteson's Avatar
Gen 1 forgot to mention that.
Matteson is offline
post #4 of 13 Old 11-30-2014, 01:21 AM
OxyG3nE's Avatar
well if you hear grinding dont start it .. the generator probably look like this ...Did the oil light when on? beacause if it was griding you would have metal all over the engine so the filter would clog
OxyG3nE is offline
post #5 of 13 Old 11-30-2014, 07:47 AM Thread Starter
Matteson's Avatar
Ya i heard a grinding then went on to ride about 3 miles. The oil light is on too. and it won't start. What the hell happened?
Matteson is offline
post #6 of 13 Old 11-30-2014, 08:36 AM
OxyG3nE's Avatar
check the # on the engine if its before 018111 then its probably the generator..
https://www.zx-10r.net/forum/showthre...tor+bullet in
OxyG3nE is offline
post #7 of 13 Old 11-30-2014, 09:56 AM Thread Starter
Matteson's Avatar
Ya it's like # 1000. This is gonna get expensive. I had to replace the sprag, starter gear and rotor nut on the buell I traded for this bike and it cost almost a grand. Now this. I guess I will drain the fluids and start pulling this thing out. I need the weld on frame. Maybe I should pull the motor now.
Matteson is offline
post #8 of 13 Old 11-30-2014, 10:29 AM
OxyG3nE's Avatar
if the gear of the generator is still good just buy a 04 generator on ebay and swap gear.. thats what i did on my race bike with the bulletin fix :p
OxyG3nE is offline
post #9 of 13 Old 11-30-2014, 05:35 PM Thread Starter
Matteson's Avatar
I just pulled it and the stator was rubbing on the rotor. It's toast. So i will be needing a new stator and rotor. Bummer. Then shim it per the service bulletin.
Matteson is offline
post #10 of 13 Old 11-30-2014, 06:23 PM
OxyG3nE's Avatar
and crazy good cleaning of the engine... oil pan will be full of metal .. but dont forguet you cannot mismatch gear of the generator
OxyG3nE is offline
Gen 2: Charging issues (stator failure + more?)- need diagnosis help 1_slo_mofo Performance and Tech 4 12-31-2013 01:51 PM
Gen 3: WTB 3rd Gen Stator and Stator Cover Magmadragoon Wanted: Buy or Trade 1 06-27-2013 07:57 PM
Success v.s Failure vr6 The Out House 10 03-22-2013 10:23 PM
Stator failure - aftermarket alternatives? richus The ZX-10R 8 08-15-2012 07:41 AM
EPIC Failure roadracer98 The Out House 70 05-11-2010 10:29 PM
