Starter motor problems - Kawasaki ZX-10R.net
post #1 of 14 Old 07-24-2014, 10:33 PM Thread Starter
Angry Starter motor problems
Ok so i have 07 zx10r. When i turn the bike on the starter motor stays running, (doesnt shut off), replaced the starter relay solenoid, not it... Took apart the starter motor everything looks fine... What in the world could it be??
superdave8213 is offline
post #2 of 14 Old 07-25-2014, 12:38 AM
Replace your relay box. The starter circuit is a 3 stage relay with the first stage easy to damage. A stator wire is connected to the relay box to energize the headlight relay when you let off on the starter button. Did you just replace your stator with a Rick's stator? I asked because that maybe the cause of the relay box failure. Be wary of the used relay boxes on Ebay to only buy from salvage yards not private parties cause those are probably blown. We went thru this a year ago with my son's 07 gen2. HTH
DaleC is offline
post #3 of 14 Old 07-25-2014, 01:52 AM
badassjake's Avatar
the push button is sticky
badassjake is offline
post #4 of 14 Old 07-25-2014, 07:06 AM
gazx10's Avatar
be aware that when starter staying engaged running it is in serious overdrive, not hard to sling it apart. seen this before. what dale c said.
gazx10 is offline
post #5 of 14 Old 07-25-2014, 07:19 AM
SkyDork's Avatar
Relay box would be my first thought as well.
#WordCrimes
SkyDork is offline
post #6 of 14 Old 07-25-2014, 10:11 AM
Gus-CO's Avatar
Unlikely but just throwing it out there is the fact that the starter clutch plate might be stuck engaged.
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
Gus-CO is offline
post #7 of 14 Old 07-25-2014, 10:16 AM
SkyDork's Avatar
That's actually not unlikely at all. The starter clutch could very likely be the problem. The difference with that is it's more of a mechanical link between the motor and the starter as opposed to electrical. I inferred from the first post that it was an electrical issue. But it's possible that the starter clutch is the problem. Certainly something to be looked at in the troubleshooting process.
#WordCrimes
SkyDork is offline
post #8 of 14 Old 10-05-2014, 09:04 AM
manuelhung's Avatar
How do you un-stick it?
manuelhung is offline
post #9 of 14 Old 10-09-2014, 03:59 PM
Try cleaning but probably replacement is only answer. We bought a used one to try first before the relay box. Nope wasn't the problem. New relay box stopped the starter running continuously. We replaced stator, regulator (3 diff. ones), starter motor (killed itself), starter clutch and relay box. Damn expensive sequence of failures. I think the Rick's regulator blew the relay box and then starter motor died from too much on time.
DaleC is offline
post #10 of 14 Old 10-09-2014, 06:53 PM
manuelhung's Avatar
Are you talking about the starter motor or starter clutch?
Gen 3: How to change my starter motor? Beanbag Performance and Tech 2 03-07-2013 02:30 PM
Gen 4: starter problems? Ninjas R Everywhere The ZX-10R 22 05-24-2012 03:36 PM
Help Problems starting..starter or starter relay (07 zx10) ninjaturtle Performance and Tech 11 08-19-2009 11:34 PM
f/s 05 zx10 starter motor 666inme Parts, Gear and Accessories 0 11-30-2008 04:13 AM
04-05 ZX-10R Starter motor F/S focalf5 Parts, Gear and Accessories 0 07-14-2008 10:29 PM
