Started some new projects on the '08 - Kawasaki ZX-10R.net
post #1 of 40 Old 01-09-2010, 08:58 PM Thread Starter
strkd50's Avatar
Well seeing how its winter and freezing ass cold here in IL I decided to change some things up on the Ten. My list of projects has slowly been getting longer for the last couple month and I finally got to ordering parts and getting started. As for my list it consists of -- Brisk plugs, routing the cc breather to the air valves, relocating my PC3 and Ign., 82lbs clutch springs, low friction wheel bearings, adjustable rear links, brocks straps up front, check for the '08 "gap", gonna move my forks up a bit for a better sag setting. I think thats about it.... I'm gonna try to post up somewhat step by step pics of some of the stuff to help out.
So this morning after waiting 2 hours for my wood burner to get the garage up to temp I started tearing down. I am still waiting for my plugs to come in, but I went ahead and got everything ready for them.
Tank and mids removed
Air box removed
I also removed the front fairing to make geting the coil sticks out
There are also engine bracket on each side under the fairing that should be removed
Here all the sticks are out, the 2 centers are easy just pull up and they come out. The outer 2 are a little more tricky, once you get them popped loose you need to bring them up as far as you can while tilting them forward. After a little wiggling they should come.
I went ahead and relocated my PC and my speedohealer while I had things apart. Pics are kinda self explanatory. Things are a little(alot) tight but after 20 or so combination's I got it all to fit.
2012 ZX-14R
#228
strkd50 is offline
post #2 of 40 Old 01-09-2010, 09:18 PM
nickalltogether's Avatar
Looks like a pretty good start. So other than wiggling does any extra voodoo need to happen to get the plugs out?
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #3 of 40 Old 01-09-2010, 09:42 PM
sweetride10r's Avatar
if you still have the front end off the bike can u messure up the front hole in the frame for the ramair i need to see if the 08 ram air duckt will work on my 04-05 zx10r frame
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #4 of 40 Old 01-09-2010, 10:04 PM Thread Starter
strkd50's Avatar
Not really, Just take your time and it will come.
Originally Posted by MagicMavis View Post
Subscribed!
I put both my PC3 and Ignition Module in the tail section and really liked the final set up. I never carry anything in there anyway.
If you have the "08 gap" I have some FREE shims. PM me.
I also am using ceramic bearings, (low friction).
I was gonna go with the ceramics but couldnt bring my self to spend the money. I just went with some non-contact seals
It is 3" wide 3 7/8" tall
2012 ZX-14R
#228
strkd50 is offline
post #5 of 40 Old 01-09-2010, 10:08 PM
JLAudio11's Avatar
Lookin good man! Let me know if you need anything.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #6 of 40 Old 01-10-2010, 12:45 PM
ninja44's Avatar
2 questions....
1. You removed the plugs just like that without removing the engine brackets?
2. Does your pitbull front stand hit the nose fairing when you lift the bike up?
Sean
08 10R Pearl Wildfire Orange
Akra slip on W/Link Pipe, Ohlins R&T Forks, Ohlins 46PRXLS, Attack Rearsets, Guhl ECU Reflash, Ivan's Block Offs, Pazzo Levers, Goodridge Carbo Brake Lines, Vesrah RJL Pads, Riflemans 1/5 Throttle Insert, R & G Sliders & Engine Guards, Puig Z Screen, Puig Hugger, Evotech 1/4 turn gas cap
ninja44 is offline
post #7 of 40 Old 01-10-2010, 01:32 PM
Originally Posted by ninja44 View Post
2 questions....
1- I'm also curious about that.
2- Mine rubs when setting it up, but once it's in the air it doesn't touch.
2005 Honda F4i-Red
Commuter stuff
post #8 of 40 Old 01-10-2010, 01:33 PM Thread Starter
strkd50's Avatar
2 questions....
No, I had to remove the brackets
Nope, I got the "new" front stand with a #15 pin. Its definitely tight, but didn't notice any contact
2012 ZX-14R
#228
strkd50 is offline
post #9 of 40 Old 01-10-2010, 04:29 PM
TENN10's Avatar
Images: 145
I put all my "gadgets" in the tail section. I may relocate them a little lower like you did after get a carbon speed battery. I don't use my "so called" storage either, I just want to lower as much weight as possible.
I also went with the sealed non-contact bearings. They're not ceramic, but way better than stock. Well worth the $. Normally about $60 I think.
I'm willing to bet, you have a gap in the forks. I made some spacers that actually "fit". Spacers would be fine, but I change my tires too often.
FWIW, My forks are up 6mm and my Pit Bull front stands w/ #15 pin fits fine. A little tight, but it will slide in without touching anything.
TENN10 is offline
post #10 of 40 Old 01-10-2010, 05:11 PM Thread Starter
strkd50's Avatar
Yeah after looking at the stock bat I might have to go the carbon speed way to. When I get the plugs and air box back together I plan on checking the alt output at idle to see if I can get away with the 4 cell
2012 ZX-14R
#228
strkd50 is offline
Winter Projects anyone????? olec4 Pictures and Videos 34 04-05-2008 09:45 PM
SPLs projects 1killer1liter Performance and Tech 9 06-05-2007 01:42 PM
Projects for the winter!! ninjamaster6-10 Pictures and Videos 6 12-05-2006 10:32 PM
Winter Projects??? champ91 The Out House 54 11-10-2006 02:49 PM
