Starrotors HID kit installation, look at pics, tell me if I got the wrong kit - Kawasaki ZX-10R.net
post #1 of 19 Old 04-24-2009, 04:08 AM Thread Starter
xx8055NIACxx's Avatar
Ok guys installed the fuking lights, turn bike on no lights, wait a few secs no lights shut bike off
the two connectors go to the light bulb, got that installed the bulb, connected all as is, but the circled area does not fit the housing for the stock power source where the old bulb was connected
did I get the freaking wrong ballast
xx8055NIACxx is offline
post #2 of 19 Old 04-24-2009, 04:12 AM Thread Starter
I think the wrong part of the kit is the lone wire that goes from the ballast to the stock power housing of the headlights
post #3 of 19 Old 04-24-2009, 04:13 AM Thread Starter
some pics of the bike
post #4 of 19 Old 04-24-2009, 06:31 AM
drkramm's Avatar
make sure the part that connects to the bike are connecting to the correct colors normal headlights are not polarized ( positive negative) hids are
drkramm is offline
post #5 of 19 Old 04-24-2009, 06:32 AM
drkramm's Avatar
and if you want to you can cut up the harness and hard wire it since they do give you a plug
drkramm is offline
post #6 of 19 Old 04-24-2009, 06:49 AM
Retired post whore
Alien10's Avatar
That looks like an H7 kit to me.
Alien10 is offline
post #7 of 19 Old 04-24-2009, 08:18 AM
fbmbks's Avatar
Send a message via AIM to fbmbks
agreed, starrotors is a good company, make sure you ordered the right size, if thats still not the problem im sure you can send the wire that goes to stock back to them and they will send you the right one, u dont wonna hard wire it you will void your warrenty if you cut any of the starrotors kit
fbmbks is offline
post #8 of 19 Old 04-24-2009, 10:59 AM
Yourmyboyblue3's Avatar
hmm before anything I would call Rick from Starrotor just to make sure that the wiring kits for the h7 bulbs are the same as the h9, If they are from what i see in the PIC have you tried to tun the Female connection around when trying to connect it to the stock power source (I know dumb question but hey second Mechanic coming thru) also it seems that two little plastic pieces that connect to those two little metal pieces I know that doesnt sound right but can you take a PIC of all the parts that came with the Kit please
Yourmyboyblue3 is offline
post #9 of 19 Old 04-24-2009, 11:25 AM
ninja44's Avatar
The harness from the ballast to the OEM headlight plug is a generic harness, it fits everything and requires splicing to fit. Most of these cheap kits come that way as H11 isn't as common. A quick fix is to get a headlight plug from a 9005 or 9006 bulb type and splice it to that HID harness and it's an OEM fit. I have an extra one at home pre made so if you need one let me know.
ninja44 is offline
post #10 of 19 Old 04-24-2009, 11:44 AM Thread Starter
ninja I have the stock bulbs still, would I be able to splice the generic connectors to the stock bulb connectors somehow
thx
GI Pro Installation w/ Pics Supraman78 Performance and Tech 14 07-27-2009 07:02 AM
StarRotors.com levers Uwan General Motorcycle Discussions 1 10-01-2008 08:08 PM
Correct me if I'm wrong, but do these sliders mount over the stock bar ends?(PICS) STREETFIGHTER50 Performance and Tech 6 10-19-2007 12:15 AM
Wrong T.R.E. Installation kawaboy Performance and Tech 2 07-29-2007 12:55 PM
wrong place wrong time 33615 The Out House 13 04-20-2007 04:31 AM
