Gen 4: 2011-2015 Standard o2 sensor what to do? - Kawasaki ZX-10R.net
post #1 of 2 Old 05-25-2011, 02:21 AM Thread Starter
Hi Guys,
I bought a Autotune and PCV, What must I do with the standard 02 sensor? If I disconnect it I will probably get an FI error?
Thanks
Omega2004 is offline
post #2 of 2 Old 05-25-2011, 06:28 PM
Supercharged Mod
Option 1: Have another, separate bung welded on for the wide-band sensor.
Option 2: Some wide-band sensor drivers have the capability of emulating a standard narrow-band sensor output. Do that, and wire that output to the existing wiring for the standard sensor.
Option 3: Some tuning packages come with wiring/software to eliminate the standard sensor. I do not know if these "play nice" with the vehicle on-board diagnostics. Theoretically, they *shouldn't* play nice with OBD, but bike OBD is currently nowhere near as sophisticated as automotive OBD.
GoFaster is offline
Gen3: Throttle position sensor, and Crank sensor, where are they? (bazzaz related) Dr.Duct_Mossburg The ZX-10R 2 05-15-2011 07:16 PM
Double standard Somatic Healer The Out House 14 01-31-2010 04:05 PM
standard gearing? zxrjohn14 The ZX-10R 1 09-20-2008 10:48 AM
Tip Over Sensor ( Vehicle Down Sensor) Papo-T Performance and Tech 1 06-02-2008 07:12 AM
Standard end can baffle jpaterson The ZX-10R 13 07-30-2005 05:43 AM
