SS brake line routing - Kawasaki ZX-10R.net
post #1 of 10 Old 04-15-2008, 05:06 PM Thread Starter
livefast's Avatar
Send a message via MSN to livefast
Sorry tried search first but to no avail... After installing a set of a galfers I cut the rubber thing off the stock lines to put into the little routing clip I beleive on the lower triple. Well that promptly fell out, and now starting to rub a little through the rubber coating, any suggestions as to what others have done, should I just tape these things up around that area or take that little bracket off so it doesn't rub or what? Thanks for any input.
livefast is offline
post #2 of 10 Old 04-15-2008, 05:19 PM
ZX-10R_Sinner's Avatar
Not 100% positive what you're talking about but in some way would a zip tie work?
ZX-10R_Sinner is offline
post #3 of 10 Old 04-15-2008, 05:21 PM Thread Starter
livefast's Avatar
i don't think so, might give 'er a try though... Yeah right where they come down from the MC, run along the fork tube, there is a bracket right there where the stockers had a rubber cover...
livefast is offline
post #4 of 10 Old 04-15-2008, 05:27 PM
Yup, I went out to see exactly what you were talking about and although I couldn't see it, just be feeling a zip tie probably won't help.
post #5 of 10 Old 04-15-2008, 05:36 PM Thread Starter
livefast's Avatar
Yeah I was out looking... I wish I could find my camera cord for the computer haha. I think I might be ghetto and just put some electrical tape around them for now...
livefast is offline
post #6 of 10 Old 04-15-2008, 05:44 PM
b_silva2000's Avatar
Send a message via AIM to b_silva2000
i took the bracket ur talking about off, it was actually causing problems with rubbing when i installed mine
b_silva2000 is offline
post #7 of 10 Old 04-15-2008, 05:47 PM
themightymezzo's Avatar
So you lost the rubber "grommet"?
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #8 of 10 Old 04-15-2008, 05:54 PM
I think when I put my lines on I put them through the rubber piece and stuck it back in the clip. Maybe get a new one and cut it then tape it around the lines (not to the line but just around the rubber) and stick it back in the clip?
I'm sure there are other ways to do it as well but this would be my route consider that piece of rubber can't be that much...I wouldn't think.
post #9 of 10 Old 04-15-2008, 06:06 PM Thread Starter
livefast's Avatar
"grommet" "rubber thingy" either way haha That was attached to the stock line (had to cut it off) so I'm going to try to just take the bracket off and check for fitment. Thanks for the input guys!
livefast is offline
post #10 of 10 Old 04-15-2008, 06:18 PM Thread Starter
livefast's Avatar
Alright I just went out and pulled that bracket off, think this should work pretty good... barely touches anything with full side to side travel, even with compression on the front end. Thanks guys, guess I shoulda just got off my lazy @ss in the first place and played around with it.
livefast is offline
10R Galfer Brake Line on 636 MC? zx-10r203 Performance and Tech 10 12-29-2006 03:59 PM
Brake Line tank zx10r The Out House 1 10-19-2006 09:58 PM
brake line question bellevuetlr Performance and Tech 6 04-20-2006 01:36 PM
Brake line & pad suggestions? Rembrant The Out House 4 08-21-2005 09:55 AM
Brake line help. maze Performance and Tech 3 04-28-2005 01:19 PM
