squeak under 20mph - Kawasaki ZX-10R.net
post #1 of 13 Old 05-31-2007, 03:16 PM Thread Starter
abadassbikerlad's Avatar
Send a message via MSN to abadassbikerlad
squeak under 20mph
i have an annoying squeak that appears around 10mph going at about 20-25 mph i have soaking lubed chain, new pads in the front with copper slip grease, the only thing i have not done is re greased the rear pads but i cant suss out what it is anyone else got this?
2013 black uk spec gen 4, full akrapovic evo carbon, brembo rcs master cylinder, brembo clutch, ohlins race SCU, woolichracing flashed ecu with stock 02 disabled, ohlins mechatronic rear shock, Suoer corsa Sc2 200 rear smoked hot bodies rear end, Puig screen, s-2 concepts seat hump,Hell hoses, brembo m4 monoblocks samco sport red hoses, samco clamps, evotech oil cap, MWR filter, Putoline syntec 4, Jmt lion battery, nearly all bolts are titanium. 55w 6000k 2.5" Hid projectors.
190.26 hp Din
abadassbikerlad is offline
post #2 of 13 Old 05-31-2007, 08:25 PM
andicog's Avatar
Images: 12
yes i,ve got same thing, only up to 30 mph. Tried same things as you and still have squeak ! Cant hear it when spining wheels with bike on stands, dealers less than helpfull ! Always ear plugs ! !
andicog is offline
post #3 of 13 Old 06-01-2007, 02:54 PM Thread Starter
yes i tried it on a paddock stand wheels in the air, still squeaks like a mouse, arrrghh
190.26 hp Din
post #4 of 13 Old 06-01-2007, 03:02 PM
Maybe you guys need to lube your axle's?
jessiah1 is offline
post #5 of 13 Old 06-01-2007, 07:27 PM Thread Starter
cheers axles don't spin but i will look at my bearings next that was next on my list, as i cant have a 1 year old bike sounding like an old wheelbarrow.
190.26 hp Din
post #6 of 13 Old 06-10-2007, 07:37 PM Thread Starter
cush drive
cured it! it was the cush drive it needed greasing. dont jet wash ya wheels !
190.26 hp Din
post #7 of 13 Old 06-10-2007, 08:20 PM
What is the cush drive? The wheel bearing seals?
jessiah1 is offline
post #8 of 13 Old 06-10-2007, 08:23 PM
bluedevil's Avatar
cush drives is the rubber inserts between the inside of sprocket hub and rear rim.
bluedevil is offline
post #9 of 13 Old 06-10-2007, 09:50 PM
bluedevil's Avatar
I must say though what ever you did abadassbikerlad to the cush drive had nothing to do with your squeak but most likely the high pressure water you have been using. The hub and rim area are always dry and don't require grease. If I where you I would check out and grease the rear axle and also make sure the rear bearings are good...but to call the resolution by putting grease in the cush drive area just doesn't sound right
post #10 of 13 Old 06-11-2007, 09:48 AM
FAF
Rent this space
If your cush drive has taken a hammering ,i.e clutching up wheelies ,it will eventually get sloppy and start to squeak, I would check how much rotation you get at the sprocket with the rear brake applied.Applying grease will only allow the cush drive to move even more in its housing.
FAF is offline
'05 gix1K vs HD in ~20mph collision daimonaros The Out House 4 06-28-2005 09:01 PM
