Gen 4: 2011-2015 sprockets - Kawasaki ZX-10R.net
post #1 of 33 Old 01-27-2013, 11:54 PM Thread Starter
zcar14's Avatar
sprockets
So I was looking in to gearing my bike and just wanted some opinions from people who have done this and what setup you went with. Was it a worthy investment in your opinion and what brand did you decide? Thanks ahead of time!
zcar14 is offline
post #2 of 33 Old 01-28-2013, 12:14 AM
ZX-10R enthusiast
dudewhrsmybike's Avatar
I'd say start off with a 16T Vortex for $30 and go from there.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #3 of 33 Old 01-28-2013, 12:30 AM
SBK X's Avatar
The 2011 + ZX10R needs re gearing badly.
Over gearing is the cheap way for manufacturers to get there bikes through testing and get them approved for road use.
Apart from the ECU restrictions the american models received I beleive that the super long gearing these bikes have stock is largely to blame for some of the poor write ups they received in comparison to other things like the BMW.
I change my gearing track depending, but no matter what my front is always at -1 and the rear is at least +1,2 or 3.
For the road go -1 at the front and see what you think.
I run AFAM sprockets but there are lots of good brands.
SBK X is offline
post #4 of 33 Old 01-29-2013, 02:59 AM
arc
arc's Avatar
Talking
I'm -1/+2 and it makes a huge difference for spirited road riding.
A.
Tomorrow, when I wake, or think I do, what shall I say of today?
Samuel Beckett, Waiting for Godot
arc is offline
post #5 of 33 Old 01-29-2013, 01:05 PM Thread Starter
zcar14's Avatar
I think im probly gonna go with the the -1/+2 also. Did you have to get a new chain when you get the sprockets?
zcar14 is offline
post #6 of 33 Old 01-30-2013, 02:19 PM
matt d's Avatar
-1/+4 here.
matt d is offline
post #7 of 33 Old 01-30-2013, 08:35 PM
Haga46's Avatar
F -1/r +2
Haga46 is offline
post #8 of 33 Old 01-30-2013, 09:45 PM Thread Starter
zcar14's Avatar
How is -1/+4?? I don't think I could keep the front wheel down!!
zcar14 is offline
post #9 of 33 Old 01-31-2013, 06:36 AM
SBK X's Avatar
- 1 at the front makes your chain slightly longer, going up in the rear makes it shorter again, so to speak.
I'd definately go -1 in the front and if your going to do the rear go +2 to make enough of a difference to realy feel it, new sprockets should realy be fitted with a new chain for optimum wear, longevity and chain length.
Get an X-ring chain if you buy another.
You can work out the ratio of any front and rear combination by dividing the number of teeth on your rear sprocket by the number of teeth on your front sprocket, it helps if you have a variety of sprockets and are looking for a small change (example, you're hitting the limiter in between corners and losing drive) or in your case to make sure your doing enough to make a decent difference.
Below was my sprocket ratio chart from last year.
You have sprocket sizes, then ratio, then ratio differences between them.
Stock front / Stock rear17 / 39 2.294 : 1
Stock front / 1 up 17 / 40 2.352 : 1 + 0.058
Stock front / 2 up 17 / 41 2.411 : 1 + 0.117
One down / Stock rear16 / 39 2.437 : 1 + 0.143
Stock front / 3 up 17 / 42 2.470 : 1 + 0.176
One down / 1 up 16 / 40 2.500 : 1 + 0.206
Stock front / 4 up 17 / 43 2.529 : 1 + 0.235
One down / 2 up 16 / 41 2.562 : 1 + 0.268
One down / 3 up 16 / 42 2.625 : 1 + 0.331
Hope that helps.
SBK X is offline
post #10 of 33 Old 01-31-2013, 06:43 AM
Look on gearingcommander.com for you speeds in eacht gear etc.
Griffen is offline
Wanted: 520 Sprockets Slow10r Wanted: Buy or Trade 3 11-03-2012 05:05 PM
For Sale: Stock Chain, Stock Sprockets, Aftermarket Sprockets Slow10r Parts, Gear and Accessories 5 09-05-2012 04:21 PM
sprockets ksoroc Performance and Tech 9 03-15-2009 01:23 PM
About sprockets.. lenshead Performance and Tech 7 11-11-2006 09:41 PM
sprockets???? 10R-rugger The Out House 4 09-19-2006 07:01 AM
