Sprocket Question - Kawasaki ZX-10R.net
post #1 of 11 Old 12-25-2008, 05:11 PM Thread Starter
KDT4's Avatar
Send a message via AIM to KDT4 Send a message via Yahoo to KDT4
Sprocket Question
Kinda new to this! If you change the front sprocket, does it make the speedometer off? If so, is there anyway to correct it?
Thanks
KDT4
KDT4 is offline
post #2 of 11 Old 12-25-2008, 08:54 PM
Postwhore with an 04
bcm0018's Avatar
Only if you change up the teeth on the sprocket. If so get a speedohealer. A sponsor might be able to hook you up but cal sportbikes is the one that actually imports them, used to be a sponsor but not any more.
bcm0018 is offline
post #3 of 11 Old 12-25-2008, 08:59 PM
Speed Freak
garth285's Avatar
usually people go 1 tooth smaller up front to help with faster acceleration.... BCM is correct and a speedo healer will be able to calibrate the speedometer back to perfect speed.
garth285 is offline
post #4 of 11 Old 12-26-2008, 10:00 AM
Thanks
Your speedo is already off by about 5 or 6 percent with stock gearing (reads high). Reducing teeth in the front or adding teeth in the rear will make it off even more.
A speedohealer allows you adjust it so it is accurate with whatever gearing you select.
TN10R is offline
post #5 of 11 Old 12-26-2008, 06:09 PM Thread Starter
KDT4's Avatar
So when i go -1 in front i need the speedohealer too Right!
Thanks
KDT4
KDT4 is offline
post #6 of 11 Old 12-26-2008, 06:26 PM
Randy G's Avatar
Thanks
Yes
Randy G is offline
post #7 of 11 Old 12-29-2008, 10:24 AM
bcm0018's Avatar
Thanks
Its not a requirement but your speedo and mileage will be off without it.
bcm0018 is offline
post #8 of 11 Old 12-29-2008, 09:13 PM
themightymezzo's Avatar
Yeah best bet if you have the $$'s is to get the Speedohealer. Installation is easy and it works great. If not just change the sprocket and have someone drive/ride alongside you at a set speed. Check it at different speeds and it will give you an idea of how much it's off.
I'd spend the few extra since sprockets aren't much and get the Speedohealer.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #9 of 11 Old 01-10-2009, 05:30 PM
PIN IT 2 WIN IT's Avatar
Location: Im deployed to afganistan right now, So Cal 661.
Send a message via AIM to PIN IT 2 WIN IT
There is no reason to spend $100+ for a speedohealer. No one really goes the speed limit and its not hard to go with the flow of traffic. Ur speedo is only like 7 mph off when ur hauling ass.
PIN IT 2 WIN IT is offline
post #10 of 11 Old 01-10-2009, 05:48 PM
BradzX10R's Avatar
BradzX10R is offline
sprocket question lynn General Motorcycle Discussions 2 07-20-2008 11:08 AM
sprocket question ash01s2001 Performance and Tech 19 11-15-2007 09:29 PM
sprocket question tjvtsportsman Performance and Tech 18 04-14-2006 12:50 PM
Sprocket Question... R1GSXRKILLER The ZX-10R 12 02-11-2005 06:54 PM
Sprocket Question? Daveszx10 The ZX-10R 6 06-03-2004 01:23 AM
