Sprocket question - Kawasaki ZX-10R.net
post #1 of 22 Old 07-17-2005, 03:04 PM Thread Starter
dr_wookiee's Avatar
Send a message via AIM to dr_wookiee Send a message via MSN to dr_wookiee
Sprocket question
I am very interested in changing my sprocket setup. I've searched the forums and found some useful information.
I live in CO at about 6200 ft above the sea so it kills my bike's ability to breathe! I weight 200+ and want a more torquey bike off the line and be able to wheelie it more easily.
I only have 1300 miles on it so far (less than a month old) so I doubt there's much wear on either sprocket or chain. But when I do something, I do it right. So should I go with new front and rear sprockets and new chain? Also, what brands are good. I see a lot of people are using vortech sprockets. Is the ERV3 chain worth the money?
What's better: aluminum or steel sprockets?
What's the difference between 520 and 525 sprockets?
I was thinking about doing a 16t front and 42t rear. Any suggestions? I've never done anything like this so I am a little intimidated.
How difficult is it to put new front/rear sprockets and chain on. Is it hard to make sure the back wheel is aligned once you put it back on? Any information is greatly appreciated. Thanks!
dr_wookiee is offline
post #2 of 22 Old 07-17-2005, 03:26 PM
Big Daddy's Avatar
Images: 38
Based on your comment 'i do it right' i'll say purchase a new chain/sprocket setup and use one of the following final drive combos.........16/40 or 16/41 W/112L chain.
Theres many choices available but a few that stand out are DID & EK chains. Sprockets are a plenty but again some notable ones being used by many are AFAM, Renthal and RRP. The difference between a 520 & 525 chain is the physical size so if your wanting the lightest but strongest chain with a high tensile strength the DID 520erv2 is it but if your not too concerned with such trivial nonesense then stay with a high quality 525.
As for attempting this yourself you'll need a few tools like a chain rivet tool, air rachet & compressor to remove the countershaft nut so if your more comfortable letting someone else do the job do it.
Big Daddy is offline
post #3 of 22 Old 07-17-2005, 05:10 PM
With only 1300 miles on the bike, I'd stay with the OEM chain and go down 1 tooth in the front. All the front sprockets are steel because of the load on only a small number of teeth.
Depending on how much acceleration you want (at the expense of losing top end) go up in the rear as needed.
Mal
'12 ZX-14R
'12 ZX-10R
65+ and medicated
zx9rmal is offline
post #4 of 22 Old 07-17-2005, 07:20 PM
crispin's Avatar
Send a message via AIM to crispin
I used to be so hot on gearing the bike untill I leared to clutch it up.
Once you learn how to use the clutch the gearing doesn't really matter too much.
I run 17/40 520 and am real happy with it
ya ya ya...
crispin is offline
post #5 of 22 Old 07-17-2005, 08:33 PM
rocketracermike's Avatar
I went to a 17/42 setup yesterday and took it out today. very please with the results.
rocketracermike is offline
post #6 of 22 Old 07-17-2005, 10:18 PM
I'd try going -1 up front. It is an inexpensive mod ($30) and if you don't like it you are not out very much. From there you can determine if you want to change the gearing further.
king-tony is offline
post #7 of 22 Old 07-17-2005, 10:21 PM
Did you happen to do any high speed runs? What was your top speed with this gearing? This is the set-up I am thinking of going to with a 520 chain
BeepeR is offline
post #8 of 22 Old 07-17-2005, 10:43 PM
Images: 59
17/42 is my recommendation. I went with a Renthal alum sprocket, DID ERV 525 chain, and a Vortex front sprocket. VERY pleased with the results. Haven't noticed any faults with going to an alum sprocket either. It's every bit as tough, maybe tougher than the OEM sprocket piece of crap.
Here's a photo:
bchild is offline
post #9 of 22 Old 07-18-2005, 07:44 AM
Thanks for the response Bchild! I was wondering if you could giv eme some info though. Would you please be able to tell me how fast you are going cruising at 6500 rpms in 6th gear? Again thank you very much
BeepeR is offline
post #10 of 22 Old 07-18-2005, 10:00 AM
Im running a 16/41 520 renthal ultra light weight sprockets and an EK chain went with EK because i wanted the green links. I live about 2 hours away from denver in gering Ne. its about 4400 ft here. It will definitly help Ive had no problem with reliability with the smaller lighter chain. I would'nt go with. any lower gearing than this though.
jeff is offline
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
front sprocket question on 18t rotts4u The ZX-10R 24 05-06-2005 08:47 PM
Installing 16 tooth counter shaft sprocket rickv Performance and Tech 3 04-21-2005 09:33 PM
Sprocket Question... R1GSXRKILLER The ZX-10R 12 02-11-2005 06:54 PM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
